Right, no spin prime. Spin primes are normally not energetic, but SpaceX found out that they can go sideways. I would hope that they'd remove the scaffolding first, and probably move the engine lift platform from under the launch mount.
They need a spin prime first. While they can do cryogenic testing at Massey's, I don't believe they do spin primes there. All the potentially energetic stuff takes place at the launch site. So spin prime first. If everything goes well, a static fire a few days later. Starting with a few engines and working up to a 33 engine test. It will all be complicated by the water deluge system. If they find any problems with the interaction between the two, then there will be delays.
Earlier I dropped in some napkin math about the deluge system needing 127 psi to directly oppose the thrust from the engines. The water deluge system test showed that they're not jetting the water straight up. That's because just as they don't want the engine exhaust to impinge the metal plate, they don't want the water jetting up into the engines (the deluge system will start before the engines fire). So the water is going up at an angle. While that might suggest needing a greater pressure, I suspect that flashing a whole lot of water over to steam is going to produce plenty of pressure below the engines, and they may be relying on that to ensure that the engine exhaust doesn't reach the metal plate.
I hope that we'll get an explanation from SpaceX on the physics of it all. It seems a much more complex environment than having a water cooled flame diverter.
