B9 has been placed on the OLM! Will they do a static fire of just a few engines and use the deluge system at partial pressure? Many engines at full pressure? Eventually all engines at full pressure?
NSF livestream of the booster being placed on the OLM
They'll walk into it, like they do all other testing. Spin prime testing, fire one engine - or a few engines - more engines, perhaps a short full engine test, then fire for the full duration that the booster will be thrusting against the plate (which is supposed to be much shorter than the first launch). I assume that all hot fires will use the deluge system.
They have an untested booster that needs to go through the normal test regimen, and they have a water deluge system for which they need to do integration testing. Perhaps more unit testing as well. They've also made repairs and changes to the launch mount itself, and those need to be tested.
The NSF guys commented that there's no hardware for hot firing on booster 9. If they intend to use that staging technique for the next test, then they've got a fair amount of work yet to do. I wonder if they plan on some kind of unit test of that. That is, static fire a Starship with the staging hardware from a booster under it. As far as I know, no existing test stand could handle that, and I doubt they'd do a static fire of the Starship on top of a gas pressurized booster. Perhaps they'll just leave it to the flight test and hope for the best. After all, they're not trying to save the booster from that flight.
Then there's the idea that SpaceX may junk booster 9 because it can't be built as a hot fire booster. Then we'd have to wait for booster 10 and its testing campaign.
It may well be a while. I've been guessing September, but they could run out a ways beyond that with all the changes they keep throwing into the mix. I wonder if SpaceX decided to switch to hot staging now (and possibly some other changes) because they had the time as a result of the launch mount repairs.
All that said, the booster going onto the launch mount last night was a pleasant surprise.
