So SpaceX is calling the system a “flame deflector”. I have to adjust my terminology!
The video in that tweet is very informative. The central area of water jets are angled out from the center but there is a surrounding ring of jets that point straight up. Interesting.
Any thoughts on that spray pattern? It looks like they're trying to create a cup shape with the water.images removed
Assuming a spherical cow...Any thoughts on that spray pattern? It looks like they're trying to create a cup shape with the water.
It looks way cooler?… which makes me wonder.. why not a pool of water 10 feet deep and be done with it?
What purpose the jet achieves a stagnant deep pool of water cannot ?
Pressure from rocket exhaust is higher than 300 ft of water (150 psi). Water would quickly be displaced.… which makes me wonder.. why not a pool of water 10 feet deep and be done with it?
Far better that way than to have the final two nouns swapped.…the Merlin pintle injector where the fan hits the sheet.
One more thing that could delay ITF-2. Obviously a massive amount of water runs off into the nearby wetlands nature reserve, you can see that in the system test videos. Apparently no details are available about exactly what that “industrial process wastewater” contains in terms of contaminants that, I assume, makes it unfit for human consumption.the company never applied for the environmental permits that would allow it to discharge industrial process wastewater into the area surrounding the launchpad as normally required by the federal Clean Water Act.
This seems to be a constant thing with environmental groups and SpaceX. I never know if this is anything of actual concern or just more environmentalist alarmism. I get the impression that because the water passes through the pumps, pipes and metal grids, it qualifies as "industrial process wastewater", and so a "review" of this would result in somebody at the EPA rubber stamping the document. After a month of waiting. I suspect that SpaceX has gone the route of "It's easier to ask for forgiveness than permission". They can afford any fines that might be imposed for failure to file paperwork.CNBC reports
SpaceX hasn’t obtained environmental permits for ‘flame deflector’ system it’s testing in Texas
CNBC reports
The next launch, and presumably launches thereafter, are going to have the rocket rising up out of one heck of a big cloud of its own making.@mongo thanks for your post, I had neglected to consider the fact that during a launch almost all the water used by the flame diverter system will turn into steam and then will be widely dispersed in the surrounding atmosphere instead of pouring off the edge of the concrete covered launch area as we saw during the recent tests.
I assume that SpaceX can point out to the relevant authorities how that reality obviates the need to file for an environmental permit.
Umm...The next launch, and presumably launches thereafter, are going to have the rocket rising up out of one heck of a big cloud of its own making.
How will this be a smaller cloud?
