From the Ars report:There's some info in the Rocket Report,
Rocket Report: NASA buys a SpinLaunch, Space Force brass visits Starbase
"It’s an amazing facility that gives you a lot of ideas of what the future could be."arstechnica.com
This is the permitting process for a second orbital launch pad in South Texas and is separate from the Federal Aviation Administration's review of SpaceX's plan to use its existing launch pad for orbital tests of Starship and Super Heavy. This probably is not a huge issue, as SpaceX likely is focused on getting the first pad in operation in Texas, as well as working on a Florida launch site. Moreover, the Army Corps said the permit process could continue once SpaceX provides the requisite information about its plans.
It is what I expect actually. Writing is on the wall. Edited to add - I think TX is going to be lucky to get a dozen test launch's. Speculation could be that endangered species are a big issue or it could be something as simple as the launch paths from there really don't work. Others have said this before, it was discussed quite a bit at some point.
Disagree. I think the OLT at Starbase will be used many times for test launches over the next few years. The FAA will come around, they just move slowly. SpaceX doesn’t need a second OLT to have a useful test launch program at Starbase.It is what I expect actually. Writing is on the wall. Edited to add - I think TX is going to be lucky to get a dozen test launch's.
Well, passengers are “payload”, correct?it would be a huge logistical nightmare to be loading payload to the oil rig launch platforms. I can see those being used for refueling launches. Have huge floating tankers alongside the rigs pumping LOX and Methane into tanks which superchill the fuel before loading it on a Super Heavy and Starship. I can see passengers being loaded there as well.
? It seems like Starship will be the most cost effective way to loft the thousands of Starlilnks needed to complete the constellation. Hasn’t Elon stated that the goal is for Starship to make the F9 obsolete?I don't see hundreds of Starlinks being loaded onto a Starship.
Or do you mean that, despite the huge cargo volume Starship could provide per launch, SpaceX is likely to limit each launch to less than 100 satellites?
Yes, but they are easily mobile to transport to the oil rig for launching.Well, passengers are “payload”, correct?
I'm commenting about the oil rig launch platforms. Loading hundreds of Starlinks on the limited space of a platform seems like a logistical nightmare compared to loading them in Florida or Starbase.I think launching payloads from offshore would be easier than Starship tanker launches, but I agree with you that given how many tanker launches are going to be required for Moon and Mars missions the offshore launch platforms would be useful for that purpose.
Nope. I'm sure the Starship will be loaded with as many as possible. Just not on an oil rig launch platform.Or do you mean that, despite the huge cargo volume Starship could provide per launch, SpaceX is likely to limit each launch to less than 100 satellites?
A recent NASAspaceflight video shows SpaceX starting construction of a large permanent structure and a new tent structure. My conclusion is that SpaceX remains committed to Boca Chica and expects to build a lot of vehicles there. I cannot predict how many will be launched from there. Maybe the plan is to barge some of them out to an offshore launch platform(s)? At this point we just don’t know.It is what I expect actually. Writing is on the wall. Edited to add - I think TX is going to be lucky to get a dozen test launch's. Speculation could be that endangered species are a big issue or it could be something as simple as the launch paths from there really don't work. Others have said this before, it was discussed quite a bit at some point.
Starbase continues to transform itself to boost vehicle construction capacity.According to RGV Aerial Photography, SpaceX…aims to replace all of Starbase’s tents with a single 300,000 square-foot (~28,000 square-meter) building that will be about 18 meters (60 ft) tall and likely measure around 800 feet (250m) long and 400 feet (120m) wide. Starbase’s tents are roughly the same height, but their tented roofs mean that only a fraction of that height can be used for ring work and only a fraction of the floor space for taller nose work.
In comparison, a 300,000 square-foot building would have almost two and half times as much covered floor space as Starbase’s three tents
Not to go OT, but I believe Teslarati and a bunch of social media superstars (Nasaspace Flight, Everyday Astronaut), IMO, are a far more reliable source than much of MSM (Eric Berger excluded)Regarding the new construction at Starbase, Teslerati reporting (not always a reliable source) says:
Fair enough, though I do not equate Teslerati with Eric Berger, who operates on a much higher level.Not to go OT, but I believe Teslarati and a bunch of social media superstars (Nasaspace Flight, Everyday Astronaut), IMO, are a far more reliable source than much of MSM (Eric Berger excluded)
Can anyone explain what I’m looking at in that photo?According to this report the B7 downcomer failed pressure testing. There is a photo, which must have come from a SpaceX employee. Not cool.
Methane tank to engine feed tube that passes through oxygen tank. Has external braces.Can anyone explain what I’m looking at in that photo?
The booster has two tanks, one LOX and the other Liquid Methane. (I don't know which is which, and a quick search doesn't tell me either definitively, but I think the bottom one is the LOX tank. LOX is denser than Methane, makes sense to put it at the bottom.) Anyway, there has to be a way for the contents of the top tank to get to the bottom where the motors are, and it has to be able to move a lot of liquid. The photo shows what is supposed to be a circular cross-section pipe going through the bottom tank, all crushed by pressure from outside. The rings welded around the pipe are there to provide rigidity to resist exactly these kinds of crushing force, and as the pipe crushed they got distorted in weird ways.Can anyone explain what I’m looking at in that photo?
