So if they install it regardless of paid/ free what would the average idle time be? For those traveling that route already what's the average wh/mi you're seeing? I can get about 330 @80 if I'm following a car on AP1 going to Florida. I've seen some screen shots of people with 400+ along that route of 226 miles.
That means 90.4kwh to get through the 226 miles at 400 wh/mi so a 100d should make it and 72a charging would net 17kwh. So an hour for the dual/high amp guys in a 90+.
For the guy like me in a 70d to get the same buffer I'd have to charge 37kwh or almost 4 hours at 40A
@charliepmayer I can charge form 14-50 just fine, I only have a single charger on my car so I'm limited to 40A. A HPWC pumping out 100A is useless to me as I can only take 40A whether it's from a 14-50 or HPWC
As an aside, whenever I see a new post to this thread I get a quick feeling of HOPE that there is a new permit or construction, only to be disappointed to see more talk about workarounds. Oh well, I'm now contributing to that phenomena.
A quick word or two about RV Parks and any HPWC installed at an RV park. I got my S back in 2012, so I was a bit of a pioneer on road trips for a while as the initial Dallas-Austin-Houston triangle wasn’t even ready at that time.
Even though RV’s with 50amp hookups use the same NEMA 14-50 standard, they don’t demand the same constant load as a Tesla trying to charge at around 10kW. Moreover RV parks are spread out with LOTS of LONG runs from their transformers to the breaker boxes at the hookup locations. Long runs lead to resistance, heat and voltage drops. Since parks aren’t expecting a constant max-load, and they are running on tight margins, my experience is that they don’t use big enough wire to support that load with that length of run.
At home you typically get 40Amps at 240V which is 9.6kW (40*240=9600). If they are using 3-phase power, the best you can hope for is 40Amps at 208V which is 8.3Kw (40*208=8320). You may get nowhere close to best case. You will start fine, but the breaker may trip after 15 minutes or after an hour. If that happens, you’ll need to wait for the wiring to cool down for a couple of minutes then dial down the amperage. Depending on the voltage drop you might find that you are charging at 20Amps by 200V which is a mere 4kW. It’s not nothing, but it is 10 hours if you need 40kWH to continue your trip.
I have had RV parks that never tripped at 40Amps. I’ve had others do fine at 30Amps and once 18Amps was the magic number. I’ve had had this happen at Texas State Parks, large new facilities and older RV parks. It is definitely a YMMV situation.
I love the flexibility of the NEMA 14-50 standard coupled with Tesla’s onboard chargers and a MWC. However, you have to have flexibility and keep ability to adapt when extending outside of the Supercharging infrastructure. The RV community is super friendly and helpful, but it is not a substitute for someone who is trying to do a “pass through” charge unless you just need a small boost of 5-10 kWh. Even then you may be waiting around for a couple of hours.
My advice is to talk to the RV park and try to get a plug as close as possible to the transformer. Also, use the app to check in frequently and use alerts (assuming you have good cell coverage out in West Texas).
Andy
