No need to send messages to developers. You can edit the location yourself as a PlugShare user.
We really need someone to accurately count them and send a message to the developers.
WHY?!? This is not the PlugShare standard. They all belong in one pin location, just like all the other multi-standard stations! The app is smart enough to do the filtering if selected.There are 15 destination chargers. You can see them from the videos, and tell where they are from the satellite view visible in PlugShare. 11 spots on the west side and 1 top left are open access, and 3 along the top (north) are for the disabled permit parking spots. There appear to be 1 'normal' and 2 'disabled' spots that have no charger associated with them (overflow? or room for someone to move out of a charging spot to let someone else charge before they are done with their 'parking' ?) Hmm, maybe for valet to shuffle cars?
Right, or add a new location, which is what I just did, just for you @bwilson4web !
PlugShare - Las Vegas LINQ High Roller Tesla Destination Chargers
Right. It should all be one location.WHY?!? This is not the PlugShare standard. They all belong in one pin location, just like all the other multi-standard stations! The app is smart enough to do the filtering if selected.
I fix enough crap on there and knew you’d man-up!Why didn't the first 5 people to complain just fix it?
Interesting, there are now two pins so PlugShare filtering for the destination chargers work
These batteries could get a head start on demand even before you arrive.
The optimal operating temperature is only needed in high C-rate applications. A Model 3 LR charging at 240kW into a 80kWh battery is charging at a 3C rate. Powerpack batteries are rated for 2 hours or 4 hours. That means that they discharge at 0.5C to 0.25C. That rate of charge or discharge does not require that level of thermal management.I just thought of something to do with Tesla batteries at this location.... you know how our batteries will preheat (if needed) as you get close to a super charger? I have to wonder if the batteries at this site also know of your arrival and start drawing a little more juice from the grid to help average out the peaks? These batteries could get a head start on demand even before you arrive.
I wasn't debating the charge rate of the battery on the car... I was suggesting that the supercharger could prepare for the arrival of vehicles by drawing more power from the grid as necessary.... after all, tesla knows who's nav'ing to which supercharger, the state of their battery and how much charge they will want.
Not as much “not work” as it is far less necessary to manage peak surge. When you’re running near flat out most of the time it’s no longer much of a “peak” to reduce. It’s a huge mesa.Not sure this would work at a large Vegas or Kettleman location (where there's a lot of business/turnover)
I don't think the Peak Shaving algorithm for reducing utility demand charges cares much about the timing of incoming cars. It will make sure that the total demand has the shape of a Mesa over time, not a mountain top. If they really get slammed and don't want to allow a spike, they just throttle all the chargers a little bit. However, at some point you have to allow months with heavy holiday travel to have a higher max utility load so you don't adversely impact so many customers.Yeah, kind of like... Well, the Supercharger battery bank is half full, but 6 Model 3's are set to arrive in 40 minutes. So in order to avoid peak utility usage charges, we should fill the battery bank up in anticipation of their arrival.
Or to keep it even simpler, they might keep the battery "topped off" or close to it, whenever they can draw utility power without exceeding the upper limit of the peak draw. That would be simpler...
RT
Anyone can update Plugshare.
There was another totally different location for the LINQ Supercharger, on the other side of Las Vegas Blvd. I did I nice job dismantling it, if I might say so myself.Yes, and they can do it “incorrectly” too!![]()
