Supercharger Live Status
Discussion in 'Model S: User Interface' started by tbleakne, Feb 8, 2017.
  1. bmah
    bmah New Moderator, Model S / Model X Forums
    Lafayette, CA, USA
    Many thanks to @wk057 for making the charging data available and to @wolfson292 for getting it on a map, even if only for a little while. Also thanks to @wk057 for the update and thoughts.
    Bruce.
    PS. I sent a note to Tesla (to ServiceHelpNA, not any specific person) politely requesting that the charging data be made public in a supported fashion (as well as the API used for the mobile apps). Probably that note will get sent to the bitbucket, but who knows...it can't hurt and maybe if enough people ask (again, politely)...???...
  2. Jonas_man
    Jonas_man Member
    Helsinki
    even if this data was a nice to have outside of the car. This is not as important as for example, Tesla adding control via their app to the weather package!
  3. EVie'sDad
    EVie'sDad Member
    Newark, CA
    Tesla could just count the stall as occupied until it registers the actual disconnect from the cabling (charging or not does not matter, the stall is occupied). that could improve the accuracy of the data shown onscreen. Unless of course they intend on indicating which stalls are and aren't charging and shaming, embarrassing those that squat in a charging stall after it has completed.
  4. Sethsla
    Sethsla Member
    Ventura County, CA
    Thank you again for this brief experiment. As a southern Cal owner, it provided confirmation of how popular daily Tesla supercharging is in our largest CA cities. Nowhere else came close to these usage levels in my observations. Three cheers!!!
  5. DadoP90DL
    DadoP90DL Member
    San Jose, CA
    Hey, what happened to the supercharger live status? It was there before and today when I am traveling and need it it is not available anymore.
    • Funny x 3
  6. BerTX
    BerTX Active Member
    Texas/Washington
    Read first, then post.
    • Like x 5
  7. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    Well that's too bad.
    I was hoping we'd have a google maps type graph for the busy times of various superchargers.
    It does make sense that Tesla wants to control that information, and how it's used. But, it's still a bummer.
  8. apacheguy
    apacheguy S Sig #255
    So Cal
    I think this is probably want it comes down to - control. I wouldn't be too surprised if we see Tesla come out with their own web/mobile interface that duplicates the functionality by @wolfson292 . I bet they were uneasy about the prospect of @wk057 exposing the API to a whole slew of users that wanted access. Not that I disagreed with that approach at all.
  9. oktane
    oktane Active Member
    Here's an idea – buy the code from Wolfson and make it live.
  10. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    The info is available on the nav screen in your car. That's where you need it.
  11. Cosmacelf
    Cosmacelf Active Member
    San Diego
    Well, at least that brief experimental site shows what we in CA had thought. Even though we have high density of SC sites, we also need a lot more! And frankly, it's been like that for 4 years. I wonder why Tesla has consistently under served their biggest market?
  12. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    I'm guessing it's a multifaceted answer. First, map coverage is an important piece of the marketing puzzle, and Supercharger infrastructure was written down as a marketing expense. At least in some nontrivial amount, it was. Second, buildouts aren't simple, especially in California metro areas. You have to balance long distance transport with local charging. And in the same vein, maybe they knew something about the usage at those chargers, and suspected that a policy change would help.
    I don't know if any of that is right, but I'm doubtful it was just willful ignorance on Tesla's part.
  13. Missile Toad
    Missile Toad Member
    Houston
    @Cosmacelf, I can think of 2 reasons:
    1) California is underserved, because Tesla can. The market gets two subsidies, both federal and state, so Tesla has to work less hard to make a sale in California as in other states -- thus, to attract non-cal buyers, Tesla has to make a more attractive Supercharger network outside California, or rebate car sales outside the state.
    2) Tesla has long modeled 10% Supercharger use, as compared to charging at home or at work. For a typical driver that is 1,500 miles of supercharging or about 5-10 hours of charging depending on if you recharge at 300 MPH or 150 MPH. If each charger stall is to support 100 cars, then that charger stall should be in actual use charging for up to 1,000 hours annually. Many people work some 2,000 hours in a year, so if you figure, business hours are the times people charge, then, an average California stall will see about 4 hours of use (assuming at least 150 MPH rates, and no worse than 1 stall per car).
  14. Patrick W
    Patrick W Active Member
    SLC, UT
    After seeing today the data are missing from the map on my S's touchscreen I read through the last few days' of this thread and I don't see an explanation.
    It was on my map yesterday. Data were incorrect so I rang Tesla and reported that. Then this morning I don't see the data on the map for any of the superchargers in my area (Utah).
  15. BerTX
    BerTX Active Member
    Texas/Washington
    #315 BerTX, Feb 17, 2017
    Sorry, my bad. This thread had morphed into a discussion of the nationwide solution that was a website with a map showing all of the Superchargers and their status, not just the ones near your car. That system was shut down by the developers last night, and that is what I thought you were talking about.
    I don't know that anyone has reported that the map in the car is no longer showing Supercharger status. I will go check it now...
    EDIT: you are correct. The Supercharger status is no longer on the Nav map in the car.
  16. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    I wonder if it is possible that someone at Tesla did not trust the "gentleman's agreement" reached with wk057, and decided to temporarily remove the data on their own.
  17. BerTX
    BerTX Active Member
    Texas/Washington
    Well, the data wasn't correct in many cases, so maybe they went to try to improve it. Or maybe it was released by accident in the first place...
  18. Sonny Daze
    Sonny Daze Member
    DC
    Either way, not very confidence-inspiring. :(
  19. 3Victoria
    3Victoria Active Member
    Victoria, British Columbia
    Maybe they are improving it?
  20. apacheguy
    So Cal
    Hmm. That would be troubling if Tesla removed the feature entirely. Hope to see it return soon.
