Hi LamboGuy,
I work for the local utility in the Clean Transportation group. There are a few steps you need to do to get charging in your parking space in a multi-unit dwelling. I'm happy to answer questions or help out.
* Get approval of your condo HOA/Property Manager for you to install a charger in your space that will be paid for on your electric bill (not the HOA power, that seems to be a common misunderstanding). Once they realize that you're paying for everything, sometimes that makes a difference. If you need to refer to Senate Bill 880 that allows you to install a charging station as long you meet certain requirements, that might be helpful. You can't move past this step until you get approval.
* Have the SDG&E Planner visit the site for a meeting. I can help hook you up with the right Planner. It would help during this step if your contractor/electrician is present, otherwise the opportunity to ask questions to the Planner on-site is lost and playing catch-up later just takes more time.
* At the time of the visit, the Planner will outline the process. He/she will be looking for specific materials later from you and your contractor. This is where most people stop, but it really isn't difficult if you approach the requirements methodically with your contractor.
* For this example, say that the building has a 4,000 amp electrical service. Your contractor will need to figure out what the maximum load is on the building for a period of time (with a clamp-on recording meter, for example). The purpose of this is to determine whether your building has the necessary capacity to install the charging station or if the service is near capacity or overloaded.
* You'll need to decide what size of service you want to add for the charging station (40 amps, 100 amps, etc.)
* During the site visit, the Planner will be looking for a location that you can install a new meter since most likely it will be difficult to connect to your existing meter. The new meter will be in your name and can be on one of the EV rates.
* Here's the important part. After measuring the building actual load over time, the contractor/engineer will need to get the as-built drawings for the building and add in your load for the new charging station, resulting in an updated one-line electrical diagram for the building. You would submit this to the Planner so they can write a "Service Order" for the job.
* The Service Order is then used to get a permit from the City, and then your electrician/contractor can begin work installing your station.
In advance of doing this, you may want to have an electrician/contractor come out and check things out to see how far the run will be from the electrical room to your space, whether concrete has to be core-drilled, etc. I've seen easy jobs and I've seen really complex and expensive jobs, so it just depends. I had one customer trade/sell their deeded parking spot with another resident that was closer to the electric room so that the electrical run was easier. They recorded the deeds and the whole nine yards...
Anyways, that's the gist of the process...I hope it helps....
Oh, and yes, the utility is working to install new electrical services for certain types of public charging stations.
It takes time to find willing site hosts and to design and construct the sites, but they are coming...
