Tesla Upgrading Its Supercharging Network To V3 For Next-Generation Speeds | CleanTechnica
- 200kW actual charging speed
- Cabinets can support 250kW max speed each
- All Model 3 battery configurations can charge at these speeds
- Supercharger V3 is a full redesign from previous generation
- V3 chargers use the industrial inverters from Tesla’s Powerpacks
- All V3 will eventually have much thinner liquid cables than current ones
- Coolant pump will be located in the base of the Supercharger and can be installed into existing Supercharger V2 stations
- Solar panels and Powerpack integration is a part of the design spec
- Up to 7 V3 cabinets per bus (or block) can be linked, with an optional connection to one Power Pack
- Supercharger V3 will have 40% better throughput performance thanks to a 96% efficiency inverter versus the 92% efficiency inverter in the Supercharger V2 units.
- The new design also brings reduced harmonics and no over-voltage sensitivity
- The new efficient design brings an impressive savings in purchased electricity
- Combined AC input is 438kVA, 526A
- Cabinets are on a shared DC radial configured bus of 880-1000
- Any extra power can be shared across cabinets
- Site master controller is 4G LTE for communication for remote diagnostics and billing
