AlanSubie4Life
Efficiency Obsessed Member
1A definitely does not work. I also used 2A this weekend, and it worked ok. However, someone was also on 2B at the time. They are laid out in pattern (from right to left) 1A, 2A, 3A, 4A, 1B, 2B, 3B, 4B. I think.
I saw my charge rate max out at 50kW (but again, it may have been shared), and then I walked away, so I don't know what it ended up peaking at. It charged to 100% in about an hour from about 40%.
I was in a rush and it was daytime, so I did not check which ones were lit up. But it seems based on posts above that likely 2A, 3A, 2B, 3B are working right now. I thought I saw someone plugged into 4A when I came back though? (Not sure.)
Definitely an important Supercharger to have working for San Diegans, for optimizing Supercharging time. El Centro is incorrectly positioned from San Diego for optimal charging, requiring a charge there to at least 90% to make it to Gila Bend in ideal conditions. (P3D+) The Yuma is essential for the "quick" topping charge, as you should be able to target 5% arrival there traveling at a good speed if you start with a full charge in San Diego.
The Nav system will not navigate to the Yuma Supercharger automatically. You have to manually select it. When I did this manual selection, the Nav screen told me "Supercharger is Temporarily Closed."
Currently, I would say it's a little risky, but you can probably count on it, but you may have to deal with slower charging (50kW?). It's possible you'll see better. If it doesn't work you're in trouble, of course - you'll be waiting on J-1772 for long enough to get you back to El Centro or to Gila Bend.
