Just got back from a long road trip from Salt Lake City back to CA along I80. With the temps in the mid 60's I put the car in range mode just to see if there was any difference in range, or how the car drove, I did not notice any. I was noticing that the supercharge speeds were low and thought it was odd that it was tapering fast and i was only getting 32kwh after the battery was at 45%, no fans were on like i usually hear when charging from low battery. After getting lunch at Lovelock, NV and the car had been charging for 40 minutes it was only at 60% I started doing a little investigation I saw that the car was still in range mode, I switched to to off and the fans then came off and the charge rate slowly started to climb. Has anyone else seen this? Is this normal, and if it is then make sure you switch range mode off when you come to a SpC. SW at 7.1 (2.12.126)
