@Randy ... you were never one of those doing all the entries tho šI liked the previous one, just post where you went and someone does the work for you
To delete an entry, look at your list of visits. Click on the date for the entry you want to delete. That'll take you to that entry's detail view. There will be an option to delete on that view.I appreciate this thread. Wanted to know how to delete a duplicate entry (and delete to reorder another). Asked and answered upthread. Kudos to the admins!
As a casual user, I find this new Supercharger.Life system easier to use than the previous one.
Yes. Found that answer circa page 2 or 3 of this thread when someone else asked the question. Quite straightforward once I gave it a try.To delete an entry, look at your list of visits. Click on the date for the entry you want to delete. That'll take you to that entry's detail view. There will be an option to delete on that view.
Any ETA?Thanks. I've captured these requests in our tracking system.
Thanks for surfacing this again. We will not implement the direct-to-login request because supercharing.life does not require a login to use it. We've been dabbling with the location dialog box and don't have a good solution yet. If we can figure out an elegant solution, we'll implement it.Any ETA?
Just went to submit an entry and those location alerts are annoying.
It is not an "active" user, so it is not a competitor and the checkins don't show up anywhere except for that user. There are a small number of people that use the app simply to track their checkins, and not participate as a competitor.I accidentally logged into one of my other Google accounts for my two check-ins today.
I have since added them to original account, but can I delete the incorrect login on supercharging.life, so it doesn't show up in any of the stats?
Yep, @bmah, it should be on the Check-in page. There is a Public notes field visible to everyone and a Private one for just you and the Admins to see.Is there a way to add a note to a check-in if you didnāt do it at the time of entering the check-in?
Thanks!
Bruce.
You'd have to delete and readdIs there a way to add a note to a check-in if you didnāt do it at the time of entering the check-in?
Thanks!
Bruce.
What kind of device is that on? Short answer is, yes, I can do that.@theflyer Is there a way to get rid of, shrink, or move the "Viewing...." white box in the Tableau maps? It blocks a significant portion of the map view.
14" ChromebookWhat kind of device is that on? Short answer is, yes, I can do that.
Hmmm. I'll see what I can do. I might be able to tweak it from my laptop. If not, it'll have to wait until I get back to Virginia.14" Chromebook
I also get this on my HP laptop running Edge at 1920x1080. The map is also double the height of my screen. This label probably displays as an innocuous header on a large screen, but covers up a substantial amount of the map on a smaller screen. I can scroll down on the page in order to avoid the label, but that also hides the tabs and labels on the Tableau page.What kind of device is that on? Short answer is, yes, I can do that.
