I think his point was the Ranger would be pressed for time given the location (not Tesla's facility). It is not necessarily reasonable to assume the Ranger should give a complementary full vehicle inspection for every call that happens.
So the context (what type of issue was the Ranger addressing) is very important.
If I recall correctly the OP said the Ranger was trying to figure out why the car wouldn't stay in alignment. The worn ball joints was probably a contributing factor if not the cause.
From the pictures of how bad those ball joints were, I would expect the Ranger to at least note the problem if he was working in the same area. If the Ranger was in that part of the car and didn't note the ball joint corrosion, that would be the only thing where Tesla has anything to answer for in this situation.
Many people here have reported they had cars that needed major suspension work at or around the same mileage as the OP's car. I have never had a car that needed suspension work at that mileage, but it isn't unheard of. We now know that it's pretty rare with Tesla's based on all that has come out recently.
Some cars are going to have abnormal wear for one reason or another. The wear can be due to common driving conditions, driver's habits, environment, or a manufacturing defect. If the car has an engineering defect, a lot of cars have problems. Tesla has fixed a lot of engineering defects over the life of the Model S, but this doesn't appear to be one of them.
The fact is I had my car in for service two weeks before the ball joint failed because of excessive tire wear. The service center aligned the front and read end.
The car was serviced at the Ross Park Mall sears service center just three weeks before the incident,
According to the NHTSA spokesman in the HybridCars.com article, the preliminary screening process is continuing and has not completed yet.Except investigation was never opened because NHTSA preliminary screening determined that there is no need for it. Nice try, but this well is dry - time to move on.
NHTSA Investigation was never opened, so there will be no action of closing it.
For your edification:
Pedants care about whether T-bone is capitalized or not.Now before you go double pedantic on me
It is so cute that you think the screening process is over.
You may want to actually read the article and apply some critical thinking (do you really think a screening conducted by a government agency would happen so quickly?) rather than depend on blogs and PR statements.
The two main instigators should be taken care of.
Whoa! Saw this in trading thread.
Contrary To Musk's Suggestion, NHTSA Did Not Call Tesla Suspension Complaints ‘Fraudulent’ - HybridCars.com
We don't know it's Keef. It could be someone who has remained anonymous. If it is an attempt to manipulate the stock price, the SEC should investigate. I'm sure the NHTSA has records of IP addresses. If all those were sent from the same IP address (or from the same block, most residential IP addresses change every few days, but they remain in the same block of addresses) then that is an indication someone might be trying to manipulate the stock price.
Unfortunately whoever did this will probably get away without any sanctions. The SEC, like most regulatory agencies, is overworked and they usually aren't interested in something this small scale.
Believe you me, it's him alright. Or maybe he's got himself some deciples now? But it is Keef, from the phrasing to the all-caps and last but not least the reference to a salvage auction Web page.
IMO it's way beyond time to quit giving these guys the benefit of the doubt.
