Yes. It turned out it was a faulty cable that they switched out. Now it works. Just doing the minimum, as stated in previous responses. I’m no longer holding the button for long.When I received mine just put the 14-50 NEMA adapter in the mobile charger and plugged the Tesla adapté on the car and it worked
have you reset the car by holding the 2 uttons from the steering wheel?
Yes, faulty cable. New one works great.I got the equipment failure message, too, when i tried to plug into 110 volts with my new model 3 tonight.
Was it your cable? Maybe there is a had batch and it's my cable that's the problem.
Not sure why he was saying all that but he is wrong. Open the charge door and shove the cable in is all I do and it works fine. Sounds like there is a problem with your car or your charger.
I also just picked up my Model 3. Pushing the button on the Wall Connector cord opened the charge door first time. And then it has never worked again since. Now I always have to open the phone app, wake the car, and open the charge port in the app...l
The car has to be awake to open the port, whether you do it by pushing on the charge door or pressing the button on the plug. That first time, you probably hadn't let the car go to sleep. If you press lightly on one of the door handles to wake up the car, I think you'll find pressing the button on the wall connector will open the door.I also just picked up my Model 3. Pushing the button on the Wall Connector cord opened the charge door first time. And then it has never worked again since. Now I always have to open the phone app, wake the car, and open the charge port in the app...l
Yes, that worked fine - thanks!I think you can also open the door by pressing on it?
Tried again tonight after driving, parking, getting out of the car and going straight to the Wall Connector. Button on the Wall Connector would not open the charge door. Touching the bottom of the charge door with my hand caused it to immediately open.
Sounds like the radio signal the wall connector is supposed to send out isn't happening...or your car is failing to receive it. The easiest thing to try is plugging your mobile connector in (120v outlet is fine) and see if that button will open the port. If it does then your wall connector is malfunctioning, if it doesn't, then the car needs to be looked at.Tried again tonight after driving, parking, getting out of the car and going straight to the Wall Connector. Button on the Wall Connector would not open the charge door. Touching the bottom of the charge door with my hand caused it to immediately open.
Not sure what is going wrong. It did work properly when I first brought the car home three days ago, but never since...
