So is this normal or not /with over 50% SOC/I got the limiter lines on a warm day with cruise control, battery was at 25%. I do however see the limit lines pop up during moderate acceleration when the battery is between 50 and 80 percent and then go away when I let off.
Would love to have a quarter mile runlog from your car and a normally functioning S85 for you to compare. Right now we only have an S85 0-60 from @Demetraki (for which we are grateful) in the Performance Metrics.My car (S85) is currently at the service center for limiting power on extended drives...even with high SOC and ~70 degree F weather...
You would definitely be in the range they used the Tyco contactors.
I have P04xxx and P115xxx and both had Tyco contactors that went out.
I would request the service center look into this for you. I don't know for sure, but heard they might be under a recall.
Could you expand on the service bulletin you reference... I have 2013 MS85 P2769X I do seem to get the power issues too at times, when the car seems warm... with more than 40-50% battery.
