Thanks for all your kind words. I can finally rest, because I just finished and submitted the app to the App Store. What took so long? Well, the Apple Watch app was completed when I made that video. But I also had to code the iPhone/iPad version. That took a whole other week to do. And then finally I had to field test this app for several days to make sure that it's perfect. I also added the features that I said that I wouldn't add to the first version, but ended up including them anyway, due to the huge support from you guys. Thanks, it really motivated me a lot to create a very feature-heavy app.
Breadcrumb mode is now pretty robust. It will keep a history of the MPH/direction/time of when the bread crumb was placed. Here's a picture of it in action. I just randomly picked one of the pins as an example:
Here's some screens of the main app:
View attachment 80405View attachment 80406View attachment 80407View attachment 80408View attachment 80409
And yes, Touch ID does allow you to start the car. Besides the Apple Watch, Touch ID keyless start was the most requested feature. Just make sure that you have Apple Watch and Touch ID enabled in the login screen to enable these features. If you don't enable it in the login screen, you'd have to sign out and log back in to change the settings.
There's support for multiple cars. Just press that white car icon on the top-right to switch between cars.
There's support for km and celsius. The app will read the settings from your car automatically, so you don't have to set them. It will also change them on the fly when you change it in the car.
The Odometer is also more accurate than what your car will tell you. I tested it out, and it turns out that it's not accurate up to an inch (even though they give me the figure in inches). It's accurate up to maybe 10-20 feet. Still not bad. The odometer just doesn't update until you move a few feet.
Camp Mode is now working, as suggested by someone. I actually camped overnight in my Tesla to make sure that it works. Turns out that sending a "Turn on HVAC" command at the 29.9th minute doesn't cause the timer to reset. The car will still turn off the HVAC after 30 minutes. Solution? Just have the app turn it back on after the 30 minutes.
I actually opened up my app to accept all sorts of commands from the internet using protocols. So if you use the in-app browser, and have a website that sends a hvac://on command via javascript, the app will do that command without any user input. You can create complex scripts this way. For example, in the morning, you can have the website tell you the temperature, check the weather first, and then open/close the roof accordingly. And if it's too hot or too cold for just simple roof opening, you can have the car turn on the HVAC a certain time before you leave the house. And then maybe even unlock the car and start the engine for you before you get in, so you don't have to wait for the car to "start up". The possibilities are endless.
