We had some discussion on this in the main investor thread.
https://www.cell.com/joule/pdf/S2542-4351(20)30172-0.pdf?_returnURL=https://linkinghub.elsevier.com/retrieve/pii/S2542435120301720?showall=true
Li-ion Mode - 530 Wh/L Li-metal Mode - 890 Wh/L
There was some speculation as to whether Li-metal is last-on-first-off or first-on-last-off.
If it is first-on-last-off I have thought of a great application....
Referring just to Li-ion part of the battery I typically plan to arrive a Superchargers with 18-20% SOC, that is because the fast charging networks in Australia are a bit under-developed, Plan B might involve a lot of waiting for a single stall charger that you hope is working.
Often arriving with 18% means charging to 90%-95% , if I have 20% "reserve capacity", I'm not happy to arrive with the Li-ion part of the battery at 3% which means I only need to charge it to 80%... Occasionally i might change it to 100% and do a planned leg of 100%->3%.
Trips where I would deliberately plan to use some of the "reserve capacity" would be rare.
So planning to use the "reserve capacity" as a contingency saves time at Superchargers and improves the longevity of the Li-ion portion.
I think this has to be baked into the cost of the car and come as a standard feature, it is probably worth a bit more money and weight to derive the advantages above.
As a "reserve capacity" that is rarely used the LI-metal part of the battery will last a long time, it is up to the cars owners how they want to use this battery, but it's state should be transparent, the driver needs to know how much reserve they really have.
We all know "range anxiety" isn't a real problem, but a feature like this would help convince some buyers who are concerned. So I see it as a feature Tesla can add as a demand lever.
