Most of the case, the drivers/transformers in the LED bulbs went bad, not the LED themselves.Yea familiar with LED lol
I have to replace them every year in my house when they start to flicker… I’ve replaced so many I save the boxes from Home Depot
Could it be that some of them are not sealed against water as well as the OEM?Most of the case, the drivers/transformers in the LED bulbs went bad, not the LED themselves.
I have purchased over a hundred leds for the lamp posts in my HOA complex. I can safely say that their lifespan is not 20 plus years. Plus there are the odd bulbs with the much shorter lifespan. I put in warranty claims for some on Amazon until they reduced the warranty period from 3 or 4 years to a year while still claiming the longer life.They call it a bulb but it's an LED. While they do have a limited lifetime like everything, their lifetime is probably longer than mine.
I don't believe that for a second. I have seen zero reports of anyone having a failed OEM puddle light. And I haven't seen many reports of broken windows either.He said the OEM lamps absolutely DO fail, its a VERY common issue.
Yeap, that is the MMA in a nutshell. It doesn't look good for Tesla any which way one slices it. If they designed it so the windows could break if the puddle lights failed or were replaced which is a consumable, that's a MAJOR design flaw. I don't understand why some owners are willing to put up with this obvious BS. What next, change your brake light bulbs or led and the rear hatch stops working? It's not supposed to work like that.perhaps worth reading - a road and track take on Magnuson Moss
Not All Aftermarket Parts Will Void Your Warranty
Seems to me that if in fact the tesla bulbs burn out as well. OR short or whatever causes the issue, then they must honor the warranty
Also it would seem that would place it in the realm of a consumable also making it Tesla's burden to show a non oem fault.
Only 100,000 on and off cycles? How about the blinking LEDs on the networking devices? They probably go on and off multiple times a second, and I've never seen one burned out before the device itself went bad.I guess the real question is what is the expected life of the puddle lamp. If the puddle lamps expected life/mean time to failure is longer than that of the car (say 15 years) than it really isn't a consumable item. There are two main aspects to the lifespan of an LED light: Hours of usage and the number of on and off cycles.,
- A simple google shows a lot of claims for a life of 50,000 hours. My HOA has leds that have been installed outdoors in lamp posts (semi-protected) that have easily lasted over 25,000 hours of actual use. During that time, we have had less than a dozen failures. I can't imagine a puddle lamp getting anywhere near that type of usage.
- There are also claims of 20,000 to 100,000 on and off cycles. I5 Cycles per day everyday for 15 years is 54,750 cycles. Well within the possible design specs of an LED Lamp.
Yep, of course the OEM bulbs fail, I'm sure I've seen reports of that on this very forum. I agree, it is a silly way to ground the windows and should change in the future (if Tesla have not already quietly done so). In regards to this failure though, honestly I can see why Tesla denied the claim. Even though their light probably will fail and possibly result in the same exact damage...it did not. Their part was removed and replaced with an aftermarket part that DID fail and DID cause the damage. They could (should?) replace it on good faith, knowing their design is poor, but obviously that's not their priority right now, making money (i.e. not losing money by paying warranty claims on aftermarket parts) is.Man I totally missed that on their site. I’ve got them too and they work awesome. But it’s a light bulb - it will burn out some day right ?
*<snip>*
