smatthew
First recall letter...... wow - so numerous!Don't even get me started on the numerous recalls.... Got my first recall letter last month.....
Tesla is refusing my repair for upper control arms because I am sitting on eibach springs and have aftermarket swap bars. The upper control arm issue is a very well known and common issue. They even came out to apply their black silicone crap to prevent the creaking just long enough to get out of the warranty coverage. Unfortunately for me, my car wasn't sealed in time and water damaged the ball joints prior to application. Now tesla is flat out refusing to touch the car that's still in warranty. I've filed a NHTSA complaint. I am sick and tired of Teslas shady business model. I understand that I am running aftermarket parts but that doesn't change the fact that even non modified cars have this same creaking issue. We(the Tesla community) need to force a recall on this part somehow. Tbh it's not even about the money at this point. I can just go with MPP and be done with it. It's the lack of responsibility for their *sugar* build quality that is upsetting. And that I will not let go. I'm gonna see it through that they replace this part or I'll lemon my car. This is the 4th time I've complained about this same issue in my 40k of driving.
.... under the federal Magnusson Moss Warranty Act, Tesla has to prove that your mod caused the issue. ...
FYI, on a Model 3, there are only two bushings on the front axle the manual calls out as needing to be tightened this way:Someone who doesn't know that the control arm bushings have to be "reset" (for lack of a better term) when the car's height is altered will just about guarantee premature failure.
And exactly how much higher is that at the FUCA when you want X mm of change of vehicle ride height? The FUCA is a ratio of the wheel or shock heights.then set the FUCA to however much lower (higher) you want with the ruler.
The FUCA ball joint moves exactly with ride height, not at a ratio.
You can't know if the car is at ride height when the front wheels are at different heights so you can't just support one corner on a random block and assume that's the right FUCA angle.
100% this is always a good laugh on the F150 forum when folks install aftermarket lifts and stuff breaks and they are *shocked* that Ford won't cover S**t ... modifying the suspension is a great warranty deleteNot exactly. It's not just about cause. They can simply claim that the modified part "contributed" to the failure. And common sense tells us that lowering springs can absolutely contribute to issues with control arms. The MMWA would not help the OP here.
the worst ones are diesel truck owners cutting out the exhaust system/ chip tuning and then later complaining when the powertrain warranty is voided and they sit on thousands of $ repair costs ... lolJeep owners are even worse...except for me : ^) I have two Jeeps (2012 and 2017) and never did anything crazy and anything I did was done with not voiding the warranty.
...That said the OP could bring case to arbitration and probably win because the joints are a known defect. And the MMA forces Tesla to prove the chain of failure which they won't be able to nor imo would they even bother too given the resources required especially in light of the known defect.
You're just assuming they'd win. They, Tesla has to PROVE the lowered stance caused the part to go bad. The fact that there's a TSB on the part proves that it was bad before. Go read the law. W/O MMA changing the tires could void your suspension, duh. Just because the springs are in close proximity it doesn't mean it's an auto void like you assume.Disagree. I've been through this before and if you modify the car in relationship to a part that failed, then it's game over. You lose. It really doesn't matter if the part in question is known to have a defect or not. Like I mentioned earlier, the MMWA has a provision that the manufacturer has to claim that the modified or aftermarket component somehow contributed to the failure of the control arms. That's a slam dunk win for the manufacturer when you're talking about an issue with controls arms on a lowered car. That's about as black and white as it gets. I understand that the control arms are an issue even on unmodified cars and I'm quite sure that Tesla could honor the warranty replacement on good faith if they chose to do so, but if they denied warranty and it went to arbitration, Tesla would 100% win quite easily.
How are they going to prove it contributed to the failure then mr. semantics?But they don't have to prove it caused anything. Read the MMWA. It only says that they have to prove that it contributed to the failure. It doesn't necessarily have to cause anything.
So no answer then huh??If you replace your factory tires with the original size tires, I'd agree that you'd really have nothing to worry about as far as warranty claim denail. But if you decided to go with larger/wider tires and ended up with suspension issues, then any manufacturer would be within their rights to deny warranty claims on suspension parts. It amazes me that people don't understand how this works.
Like I said though, manufacturers can still honor the warranty in good faith. And many do, if for no other reason than to keep their customers happy. But if they decided to take a stand and deny warranty coverage, they'd win for sure.
No answer to what? I already explained tires to you. Stick with original sizes and you're good. Go bigger at your own risk.So no answer then huh??
