Correction, now in SS. I think it's a mistake - I think SS for Pros makes total sense, but SS for tours is just a lazy response.
Effective 1/1/2021
Effective 1/1/2021
#27475 Tesla Model 3 Classing
In accordance with section 3.2 in the Solo Rules, the SAC recommends, and the SEB has
approved, the following change to Appendix A:
Move from BS to SS:
Tesla
Model 3 Performance (2018-2020)
3.2 VEHICLE CLASSIFICATION
New car makes, types, and models will be classified by the SEB as soon as
sufficient information is available to do so. The SEB may reclassify a car at
any time up to and including December of the calendar year following that
of the initial classification, without the approval of the Board of Directors.
If a manufacturer issues an official specifications change (software or
otherwise) to any previously-classed vehicle and that change is deemed
significant enough to warrant reclassification, the SEB can request the
BOD to approve an immediate classing change. “Initial classification” in-
cludes the addition of a new listing on an exclusion list.
That's my only thought as well - I'd be really surprised if they changed the seat but it's possible. Let me know if you get it figured out, I don't know what to say about that one.
It looks like this bar, and there's a lot of clearance on mine, but I did play around with vertical and fore-aft movement to get everything in:
I don't mean to hijack this Performance thread, but since you asked...being a RWD owner, I would prefer that EVs were mixed with ICE cars into classes based on weight to HP ratio + mods. The problem with EV only classes is that there are too many sub-classes. Take Tesla Corsa for example. They have the Tesla Challenge with the 5 classes:One thing I'm really interested in is how you guys feel about electric cars being put in a class of their own as opposed to mixing them in with ICE cars.
You sure it's not suspension droop on one wheel that's doing it? How can you tell it's bottoming out, because normally you can not tell when suspension bottoms out going slow, as there are squishy bump-stops that absorb the impact.1st up when I back out of my garage to my driveway there is about a 4 inch drop. After install I bottom out on something as it compresses. The stock suspension didn't do that. I know that's probably not a real world scenario so I can deal with it if it is not something installed wrong/dangerous. Hard to reproduce for installer or video, etc.
You don't want 0 camber if you're planning on any aggressive driving. 1* is a not bad for street and some performance driving, but you want significantly more for the track. You should check your toe values if you feel that the car is too unstable. At 1* camber that shouldn't change driving feel much.2nd, the installer installed all the shims and could only get the front camber to -1 for normal street config. What is recommended? Can more shims be installed to get to 0. It is pretty knife edge steering and AP tends to ping pong more. I don't know yet what the no shims setting would get.
Changing wheel size does not typically change ride height significantly as typically you keep the wheel height and circumference close to stock.I also was thinking that I would eventually run (suggested) light weight 18" with (suggested) tire and spec and that would drop me another inch lower for track and I might not have to adjust the height.
T20 was a bitch to unscrew. And another one was T50, not T45. Backseat pillar cushion is not sitting correct anymore - makes sounds if pushing it, but can't fix it... Used your advice to not push the headrest down and now I can take out belts and out back easily.A couple of things that may further help someone doing the belts.
The seat going up also goes forward to expose the t20 screw. It doesn't need to come all the way out, just enough to release the metal on top.
The drivers attachment bracket is attached with a t45 and will need to bend outward as you tighten as the inside of where is it attached is not flat.
The headrest doesn't need to come off, just up enough to feed belts thru. I actually didn't push mine down to where it clicked again. I left it so it comes up without doing the clips and I can remove the belts. The clips are farther down in there than you think.
The back seat of mine doesn't have the metal hooks on the trunk side. The seat belt attachment 16mm is low on the pillar not on the base.
This is what I discovered too. I looked for another suitable harness which is EU certified, but couldn't find anything as suitable as the Quickfit, so I'm bringing some in from the U.S. as well.BTW, in EU, Quickfit is not available since it's not certified. Made in Germany only for US. Had to sneak it back.
Total newbie here but I am trying to learn from looking at info from this thread and "MASTER THREAD: Comprehensive Road-Course Modification Guide — Optimizing the 3 for the track"
I guess I will ask in this one as it seems more MPP centered and that's route I went.
So I had the MPP coilovers, rear camber & toe arms, front camber arm, steel brake lines, UP street/track pads, Castrol racing brake fluid, all installed with MPP recommended street settings. I have a 3 performance with the 20" wheels and this is my daily driver but will track too.
Hi there, these are all MPP questions, in the future please email us so we have a chance to answer them. Here we go!
It sounds like after lowering your car you are having ground clearance issues between the garage and driveway. If there is a steep angle, the flat underbody of the Model 3 will happily scrape against things. This is why many of our lift kit customers raise their car beyond the stock ride height, their condo parking garage entrance is too extreme.
-1.0* camber is perfect for street use. We can send you one set of additional 2mm shims, but that is usually for someone running a very low ride height that is having trouble getting below -2.0* of camber.
3rd, do I just carry the front knob around for adjustment? Is there a way to have it installed that leaves it with it being accessible? If anyone has a pic that would be great.
Most people leave the adjustment knob in their center console. If you try to leave it in the damper it can bounce out and get lost!
After that, I was thinking that I could get the adjustments you guys do or get final settings and work with my alignment guy and document that when I get to the track I can just know to do 5 clicks here, 4 clicks there, remove shims, loosen nut - turn 1 turn clockwise and tighten. Then reverse when done.
Here are some starting points for you. Every driver, car, and track are different. There is no one size fits all, otherwise, race engineers would be out of the job!
Low Grip / Technical Track Damper Settings (clicks from full stiff – higher number is softer)
Front Compression: 9
Front Rebound: 8
Rear Compression: 6
Rear Rebound: 7
High-Speed / High-Compression Track Damper Settings (clicks from full stiff – higher number is softer)
Front Compression: 5
Front Rebound: 5
Rear Compression: 4
Rear Rebound: 3
Street Damper Settings (clicks from full stiff – higher number is softer)
Front Compression: 14
Front Rebound: 13
Rear Compression: 14
Rear Rebound: 13
Track Alignment:
Front Camber: -3.6 °
Front Toe: Varies. Generally -2mm total
Rear Camber: -2.6 °
Rear Toe: Varies. Generally -3mm total
Street Alignment:
Front Camber: -1.1 °
Front Toe: -1mm total
Rear Camber: -1.1 °
Rear Toe: -1mm total
The front upper control arm instructions have an easy-start guide for making FUCA adjustments at the track, you can find it on this page: MPP Corkscrew Front Upper Control Arm Installation Instructions | Mountain Pass Performance
Unless your 18" tire setup has an overall diameter that is 2" less than your current setup, your ride height won't drop by 1" with different wheels. We also strongly advise against running smaller overall diameter wheels/tires, it just runs the motors at a higher RPM and in field-weakening even sooner than normal. It would be best to find a ride height that works for your daily driving and stick with it at the track as well. There is no point in raising or lowering your car for the track unless you running in a competitive series. Even then, changing the ride height necessitates a realignment, which would be costly (one alignment after lowering, one alignment after raising) or simply time-consuming if you are going to do it yourself using strings.
Thank you for any advise in advance from you guys that know what you are doing.
Appreciate it.
IIRC, you would not be able to run SS in a car with more than the factory camber settings. I remember Steve Equina getting busted for that in ESP. Where do you run a Model 3 with additional camber for SCCA SoloII? I've been out of the game 15 years.
The car is classed in ASP, although a lot of the MPP upgrades use sphericals which as noted in this thread somewhere earlier are not allowed in *SP, which is asinine, but that's the SCCA for you. The car is legal in SM as well, and there is also a new EV class that's basically intended to allow whatever you want, but on 200tw, however rules haven't been released yet.
We sent you some goodies today John!![]()
Just curious why the OP is using MRR M600 19x10" (24 lbs) wheels for road racing when there are much lighter wheels options available.
