interesting line there. "for larger projects"
$250/kWh was already called out for the price of powerpacks at 100 kWh per pack, $25,000. Now, $500/kWh is still a number just starting to be seen on full system eligibility costs when looking at the claimed full system price listed in the california s.g.i.p. data that is publicly available. A 50KW system (presumably two powerpacks @ 200kWh) would be $50,000 in batteries. The projects are posted as $100,000 eligible price. that seems to go with the statement. But is a 2-pack project really "for larger projects"? And is it a good guess to think that a 50KW system is 200 kWh? Because the requirement of s.g.i.p. is to run at the rated power for 2 hours or more. You don't go to 100% battery charge and then down to 0% with Li-Ion batteries. And if 100 kWh powerpacks are just that, 100 kWh, then somehow they must meet this 2-hour requirement. Some recent project additions are for power ratings of 242.5 KW which is not the typical round-number that has been used (50, 100, 200, 800, etc.)
The 242.5KW systems have eligible costs of $730,000 - or $3010/KW.
We don't know the full size in kWh of such installs but it must be at least 220% of the KW rating. If they go with just a slight buffer, then that is 500 kWh but won't run for 2-hours at 242.5KW for long as batteries will lose capacity over time. I think s.g.i.p. should require the 2-hour power output production at rated-power for their installation sign-off and at 2 years after install as well (700+ cycles). If a $730,000 system of 242.5KW uses 600kWh of powerpacks (6 of them), then that is $1216 per kWh. These systems reserve $424,860 per install, so you can see much of the project is easily paid for by the s.g.i.p. funds.
Going back in the s.g.i.p. data - you can find systems with much higher prices per KW so the prices are dropping. Other companies need to react to these prices or be priced out of the market. I think Tesla is charging "too little" for the systems today. Even at $30,000 for 100 kWh, they are ahead of the competition by a large margin.
