So the 5500 here is not counted via P&D under deliveries right? Also with 4 factories we should see higher amount of stragglers sitting on lots or being transported vs 2 factories.Rob should have the production numbers so look out for his YouTube video. 5k exports seems low so maybe the production number is much higher that wasn’t counted (at docks/on the factory lot)
We're exporting record amounts of crude oil and refined products. Well above and beyond the amount of crude released from the strategic reserve.
It's a good thing that Tesla could export all those MIC vehicles out in September since they were having demand problems in China. /s
Well, I'd call that a demand cliff, it's just we're at the bottom of it ready to climb it.
Since all these people were wrong about China demand, I expect we’ll climb 15% tomorrow. /sWell, I'd call that a demand cliff, it's just we're at the bottom of it ready to climb it.
Tesla doesn't compete in the low end today because it's either not economically feasible/desirable, or the product is not capable enough for their standards.
Anyone outside of Tesla making a cheap EV with decent range is likely sacrificing margins. Don't expect any volume production of significance, despite popularity. EVs with small batteries have poor range and poor torque. Basically the glorified golf cart. Sure there's a market for this, but Tesla's more than happy to let someone else tackle that segment.
With Tesla's manufacturing efficiencies, they likely could produce the best-spec'd low-end EV. But as long as they haven't tapped all the demand for the current 3/Y segments, there's no reason for them to rush to the bottom, where margins are crappy. Maximizing profit now allows them to continue to grow (more factories), which will then set them up to handle the volumes that a decent econobox EV would generate.
If I remember correctly, Martin Viecha, Tesla head of IR, said that the next vehicle platform would be shared by the robotaxi and a more economic EV. He then talked the comments by saying a more economic EV will not need to come before the robotaxi.A sensible target is making a 20%-30% margin on an entry level EV in the $25,000-$30,000 price band,
It is not worth doing if:-
1. The price of the compact initial Tesla is far above $30,000.
2. The initial margin on the compact Tesla is less than 20%.
3. The resulting vehicles involve too many compromises, and seem cheap, or perform badly.
I think Tesla will do it, and it will eventually be 3-4 compact models on the same platform, that will rule a line on how far Tesla will go in that direction, for sometime, perhaps forever.
Tesla may also make a range of Cyber vehicles variations of the Cybertruck platform, I see that as a separate category which probably doesn't overlap
As per the Cybertruck I see the compact vehicles as a design challenge, the right designs at the right time can hit all of the targets, but a lot of time and effort is required to get the design right.
The compact vehicles probably also need mature 4680 cell production, producing cells in volume, with high reliability, at a good price.
Why I think this is needed is, to get to 20 Million vehicles sold worldwide, and support the volume of vehicles sales that allow a full build out of charging, delivery and service in all markets.
I agree. SP should be up.Since all these people were wrong about China demand, I expect we’ll climb 15% tomorrow. /s
Borrowing funds for non-productive use at high and rising interest rates.What if they borrowed the money to do the buyback? That might explain participation of S&P in the game of late. I think this was alluded to in the SMR video I posted as explanation for the sudden comprehension of how well Tesla is performing by S&P.
The power consumption of the Semi is mostly the load of the actual work being done to overcome frictional forces, so there's minimal opportunity for improvement beyond Tesla's stated specs in 2017. The range of uncertainty is only like 5-10%.
I've calculated an estimated 1.1 kWh per mile of air drag power consumption at 75 mph using Tesla's 0.36 stated drag coefficient and 0.8 kWh per mile from rolling resistance.
Tesla can only do so much to make a big box with a 10 square meter cross-sectional area actually aerodynamic. Most of the design win was already achieved in 2017's design simply by making the front of the truck smooth, sloped and bullet-shaped.
It's also extremely unlikely that Tesla has found a way to revolutionize rolling resistance, and meanwhile their 82k lb fully loaded weight is more than the 80k lb legal limit for Class 8 diesel trucks, which increases the rolling resistance by 82/80-1 = 2.5%, all else being equal. The energy loss from rolling is due to vibrations, the material properties of rubber, and the road surface. Tesla may have squeezed out some tiny gain in this area but there's not much room for improvement.
The only way Tesla could get a major improvement in these areas is with platooning, such that one truck lowers its wind load by drafting behind the truck in front of it.
In the longer run, the only possibility for terrestrial freight transport at these speeds to require significantly lower energy loads is to do the platooning in a tube that contains the airflow and has either rails or smooth, clean pavement. One of these from Boring Co could do the job:
I know it's sarcasm but to be fair the news came out over a day ago so you can clearly see we climbed 15% yesterday.Since all these people were wrong about China demand, I expect we’ll climb 15% tomorrow. /s
Lots of miscalculations in this article.Here is a good breakdown of efficiency:
A 1.47kwh/mi with 2016 tech by a legacy OEM. So 650kwh could be the actual battery size.Electric Long Haul Trucks
I’ve delved before into what it would take to convert the world’s car fleet to battery power with our current battery technology (spoiler: lots and lots of cobalt). What about trucks?www.sevarg.net
I assume you are referring to this article?If I remember correctly, Martin Viecha, Tesla head of IR, said that the next vehicle platform would be shared by the robotaxi and a more economic EV. He then talked the comments by saying a more economic EV will not need to come before the robotaxi.
Why not?I'm not expecting 30% margins on autos come 2025.
That depends on whether a Robotaxi is optimised for a typical number of passengers, and what that typical number of passengers is.I think Robotaxi will be a lot bigger than cheaper Tesla, so don't think they will share the platform.
I think the author's math is not accurate and it's also not a clean comparison for three reasons.Here is a good breakdown of efficiency:
This is very similar to my thinking, no need for a centre console, seats closer together thinner frontal area, less drag, more efficient.Imo Tesla should make a tiny car. Like the Smart car they showed for Daimler a long time ago, but this time done right. No center console and have the seats next to each other. Two seats only... Hatchback, tiny frunk. The new LFP from CATL. No options other than color and FSD(start with delivering FSD models until they run out of demand). A bit fugly is okay. Something like this one:
Mary? Leaders don't need no stinkin' help....Give Ford enough price increases on the Lightning and Mach-E and they might be able to squeeze out a profit in a few years... GM? Not so much unless Joe helps Mary out in some way.
