I was down to 33% at end of peak yesterday and having some spotty PV generation.same questions as @swedge but i guess we are going to find out. the thing that sucks is that it's very cloudy today and i ran my powerwalls down to 25% last night. but if the event doesn't start discharging till 6PM then i'll probably reach 100% before then.
That did help, thanks. In fact very interesting - it looks like some of them getting over a thousands dollars a year from that program.I suspect your best bet is to check the discussions in the Connected Solutions thread.
If you had the grid charging option, you may be able to top it up now: Enable grid charging, set reserve to 100%, and then set reserve back down to your normal setting after it has charged up.same questions as @swedge but i guess we are going to find out. the thing that sucks is that it's very cloudy today and i ran my powerwalls down to 25% last night. but if the event doesn't start discharging till 6PM then i'll probably reach 100% before then.
FWIW just turning on grid charging was enough for me. Once I enabled grid charging, the Powerwalls started charging at 5 kW each. I think that the VPP event will make it charge to 100% from grid if you enable grid charging.If you had the grid charging option, you may be able to top it up now: Enable grid charging, set reserve to 100%, and then set reserve back down to your normal setting after it has charged up.
SW
Well like storm watch, if you only do it for special cases it becomes a rounding error in the total use. It's not binary in that if you use it once, they would negate the ITC.well there's still the matter of the ITC. not really sure if we should ever grid charge if the ITC was taken. don't want to find out the hard way that i shouldn't have been!
I think that's a reasonable concern. I got my Powerwalls at the original price with an SGIP rebate, so while I'd be very annoyed if I would have to pay back the ITC, it wouldn't break the bank. For commercial projects, the amount recaptured is prorated annually over five years, so I think it's likely that something similar would apply to residential projects. Given the direction the new legislation is taking on this, I'm hoping it will never become an issue.well there's still the matter of the ITC. not really sure if we should ever grid charge if the ITC was taken. don't want to find out the hard way that i shouldn't have been!
Same behavior for me. Typically 100% of solar goes to the grid and home runs off PW. Taken in the 4-5 pm hour.4 pm rolled around which is peak time for me on ev2a and the house is NOT consuming from the powerwalls at all but directly from solar with the balance of solar going to the grid. I assume this is intentional to keep the batteries full until the event starts. Currently it says preparing for event.
I'd be fine with this if the event consumes all of the PW capacity but as it stands right now, I'm losing money by not exporting all solar production to the grid during peak. What would be even worse is if the event doesn't actually happen or it draws very little from the powerwalls. If that ends up happening today leaving my powerwalls near 100% late tonight, which is not good for them to leave them fully charged that long, I will be withdrawing from the program first thing tomorrow morning.
If you login using the IP of the gateway and click "Summary" there will be a reported setting called "Site Export Limit".2 powerwalls but only exporting 5.3KW. i think this is because my solar inverter is only 5KW and so that’s all pge has approved for export. there were a few days after the “export everything” feature appeared where my system exported 10kw, but that ended pretty quick.
