Looking forward to it. I've lost many a data because of nap mode and although I know I could turn it off I don't want to to sacrifice vampire loss in this cold chicago winter...
How can I set it for the command line tools to display speed and charge in kilometers instead of miles?
teslacmd - g does output that the car uses kilometers!
That still makes me believe it could be an option on the command line for this software . Instead of creating a hack with a pipe through an awk script... I use Debian 6.0. I use bash, and I'd like kilometers. And I'm not good with sed or awk .It should be very simple to pipe the output through an awk script or something to convert before printing. What OS and command shell are you using? Which charge measurement do you want?
I have a problem with visualize.js. It complains that:
Unable to load /home/<user>/.teslams/config.json; web server authentication turned off
didn't find 'visualize' property in config file, authentication turned off
But the file is there at this location and looks like:
"username": "****",
"password": "****"
"visualize":
{ "id": 1, "username": "****", "password": "****" },
I wrote that code and your analysis is correct. The error reporting of the config file code is surely lacking, but once you give it a correct JSON file it should work.I didn't write this piece and a don't use it personally. Is this something that just recently stopped working (perhaps a version issue) or have you never been able to get it work?
--update--
Looks like there may be a missing comma between the end of "password": "****" line and the start of
the "visualize" line that makes this invalid JSON.
teslacmd -c | grep 'battery_range:' | grep -v '_battery_range' | cut -d : -f 2 | sed 's/,//' | awk '{printf "range = %4.2f km\n",$1*1.609344}'
Unfortunately, adding the comma doest not solve the problem. Same error message.I wrote that code and your analysis is correct. The error reporting of the config file code is surely lacking, but once you give it a correct JSON file it should work.
I'm interested in the way how you transform your MongoDB data into these charts. Is there a possiblity to shed some light on that?
Thanks for the info Hans. I'll try to contribute something to this project.Dirk did pretty much all of the visualize stuff so I can only point you to the code without having the level of understanding that the original author would have.
The chart data is retrieved using jquery and there are some conversions of units (metric vs imperial) as well as multi-lingual support (English and German) in the javascript libraries.
The main energy chart page is driven from the file ~teslams/examples/visualize/energy.html. This parses parameters in the url to tell if its supposed to display metric or german or whatever and then uses the conversion scripts in ~teslams/examples/visualize/otherfiles/lib.js to get the right values and language.
The first chart (bottom one in your post) uses data collected using the streaming API and the other chart (top one in your post) used data collected by polling the REST API. Unfortunately Tesla does not have consistency in the data they return from various sources. After all, this is just for their own mobile app so it's not designed to be for third party developers.
The streaming API reports power pulled from the battery pack while driving, or put into the battery pack while charging or under regen braking. It only reports power in kW, not separate values for Voltage and Current. The point of collection for this data in somewhere internal to the car after the onboard charger (i.e possibly DC power from the battery pack or some place between the battery and the electric motor). Since the battery and motor are the same worldwide, these numbers are the same for all cars anywhere in the world.
The REST API reports AC power, going into the onboard charger, which differs throughout the world. The REST API does report separate values for Voltage and Current and I think the Power value in the chart is calculated. In North America it is sufficient to just multiply the voltage by the current to get the power (P = V*I). In cars with three phase chargers Tesla under reports the current by a third. I'm not an electrician but I suppose its just the current represented in one of the three phases. I'm pretty sure that ALL metric countries do not use 3-phase power (Canada for example does not) so it's not sufficient to just key off the existing parameter for metric. This one chart need to be updated to take another parameter to indicate the presence of a three phase charger and multiply the power value by 3 when the REST API is the data source. The all the other navigation menus that call this HTML page need to be updated to supply the proper URL will this parameter.
If anyone is up to the task of tackling the coding I would be happy to help them out but I do not have a car with a 3-phase charger on board nor do I have a 3-phase power source for testing.
I put up TeslaMS 1.0 on github and the npm repository. This release uses the new "6.0" REST API and folds in a few enhancements to visualize.js thanks to Chris Crewdson. There might still be a few items to debug but it's very backward compatible and the example apps all work for me. I am looking for volunteers to try it out for compatibility as well as access (since I know some owners are experiencing a lack of access to the REST API from most third party apps). There _may_ be issues for those outside the US so if this breaks things for you and you are in Europe then contact me and we can try and set the "locale" correctly to make things work for you.
If you use the teslams functions to build your own apps, the biggest change to watch out for is that the "id" of the vehicle is now an integer that is too big for JavaScript to handle natively. Strange but true. I used the json-bigint module to handle this and convert the "id" field into a string in all the JSON returned by teslams functions with the exception of teslams.all() which was added explicitly to return the raw JSON as sent by Tesla.
Lately, the recording of charging voltage/current/power has been unreliable. Here's an example over the past two weeks - we plug in and charge every single day, but you can see plenty of occurrences where we've driven but the data hasn't saved.
Today, in particular, we drove the car on 3 separate trips, charging 3 different times, and it wasn't captured. Anything that has changed here?
See the graph below -- the day lines line up:
