I would like to update my early post about harsh ride. Another several hundred miles and either I am getting used to it or springs and tires are breaking in a bit. It still rides a bit stiff but the jarring on bumps has decreased a fair amount. It has smoothed to the point it is no longger an issue for me. I just came back from a 300 miles trip. And while the Model 3 is still no Model S in ride comfort, I was still able to do the trip enjoyably with no fatigue at all. Remember, I am coming from a Model S. Friends who ride in my car (they having average small cars) remark that the ride is very smooth to them.
Any of you worrying about ride. I'd say, you'll likely be fine. But! If you can afford an S, cargo space, and a quiet and smooth ride matters to you over the sport handling of a 3, get an S.
I said earlier in this thread that everything would loosen up and settle down somewhat after a little while.
Springs and especially shockies will “break in” from new. Tyre pressures will also make a big difference- even dropping by say a few psi will help the ride, (but will slightly affect both handling and range.)
And remember...... The optional bigger diameter rims
WILL give a harsher ride.
I’m sure we Australians are notorious in the U.S. for some things, (we all have our good and bad points)
, but you Americans are “kind of” infamous here for making cars with an overly soft, mushy ride, (...especially in years gone by.)
Having said that, I own a 2014 Grand Cherokee with coil suspension (not the optional air suspension) and I’m quite happy with both it’s ride, and handling. (I purposely stuck with the standard 18” rims on it as I didn’t want the harsher ride given by larger diameter rims.)
Anyway going by this thread I’m guessing that some of you Americans would
like a softer ride, and happily accept slightly worse handling.
(The thing is, it won’t be long before you’ll be able to change springs and shockies with aftermarket suppliers to get a softer ride- but handling will suffer as a result.)
My advice would be, if you don’t like a somewhat harsh ride:
1. Give it some time to settle in.
2. Try lowering the Tyre pressure just a little bit.
3. If you’re more interested in ride than handling,
don’t get the larger diameter rims, stick with standard.
(Ultra low profile tyres give a pretty harsh ride in any car.)
If you’re still unhappy, start looking for aftermarket suspension suppliers. I’m sure there will be other options before too long.
Cya, and G’day from downunder.
