I'm ready to reshoe my 2018 X, 100D. My local dealer has recommended the Continental brand and I see it is not run flat. I do carry a pump, I know it depends upon the nature to the puncture. Thoughts? 2k installed and aligned.
None of them are run flats from the factory, why not go to a local tire store get an estimate from them tooI'm ready to reshoe my 2018 X, 100D. My local dealer has recommended the Continental brand and I see it is not run flat. I do carry a pump, I know it depends upon the nature to the puncture. Thoughts? 2k installed and aligned.
A ~$300 option I liked here: Any great new tire choices to replace OEM 20”?I'm ready to reshoe my 2018 X, 100D. My local dealer has recommended the Continental brand and I see it is not run flat. I do carry a pump, I know it depends upon the nature to the puncture. Thoughts? 2k installed and aligned.
TPMS?Sounds expensive. How many miles on the original set? You may not even need an alignment. Depending when you did your TPMS, you may want to proactively replace those as well.
Tire Pressure Monitoring System no need to replace these as suggestedTPMS?
HV batteries have failed under the 5 year mark should that be replaced as well. How about suspension components that may fail, just replace all those too, hell just replace the car because something MIGHT fail.That's bad advice. TPMS does not have user serviceable batteries you see the earlier ones fail around 5 years. Unless OP has access to a tire machine, they will be paying a mount and balance fee to replace a TPMS.
Oh my die on a hill, so Now the car will spontaneously combust on a hill if a tpms sensor stops working? Just show me one report of a death due to TPMS failure. If only common sense could be taughtYou really want to die on a hill over $35? The cost to mount and balance is probably $20-25 a wheel. I own the hardware to mount and balance myself yet I replace my TPMS every 5 or so years. Do as you will. The industry recommendation is to replace the sensors they reach 5 years.
i have to agree with this one.Tire Pressure Monitoring System no need to replace these as suggested
i see ur point but i think ur wording is not the best here.You really want to die on a hill over $35? The cost to mount and balance is probably $20-25 a wheel. I own the hardware to mount and balance myself yet I replace my TPMS every 5 or so years. Do as you will. The industry recommendation is to replace the sensors they reach 5 years.
You disabled them and you have not DIED yet I guess you avoid hills.It's not about checking pressure. I've disabled the system on my other cars because I swap wheels often. It's about an annoying nag screen and taking the time out of your day to do something later when you could do it now. If it were hundreds of dollars I'd leave them until they die, but for the cost it's a no brainer.
Just avoid the poor information and blatant liesGuess it's time to start avoiding this forum.
