Stock tire/wheel weight 51.3 lbs on the bathroom scale
Track tire/wheel weight 47.6 lbs, 3.7 lbs lighter
Nice! Mine come in around 46 lbs, but that was at $3.2k for wheels + 1k for tires (265/35/18)
14mm x 1.5 RH/T is what's on the box. Maybe it's just an appearance thing?These probably user tuner nuts (12mm) instead of tesla stock 14mm nuts. Very common on wheels like this, my winter ones do.
Will do! Next track day (night) is schedule for late August. I'm curious too about the camber, but the main purpose for me was to have something else to run so I don't tear up the street tires each time I'm out. Had to replace 2 PS4S with 2000 miles on them last time, corded the outside edge.Looks much more practical and ready for track use. After your next track session, let us know whether you still just end up wearing the outside of the tires...I am just curious how much value there is in wider tires without the camber also being adjusted. Eventually I'll need to decide between 8.5 and 9.5 if I end up getting autocross wheels.
14mm is the diameter, 12mm obviously wouldn’t fit. I’m using the factory nuts on my TSW wheels. Admittedly I didn’t check if the taper is the same (pretty sure it is) but that’s the only reason the factory nuts wouldn’t work. The factory ones are ugly without covers though.14mm x 1.5 RH/T is what's on the box. Maybe it's just an appearance thing?
Here's the stock ones vs the ones they gave me14mm is the diameter, 12mm obviously wouldn’t fit. I’m using the factory nuts on my TSW wheels. Admittedly I didn’t check if the taper is the same (pretty sure it is) but that’s the only reason the factory nuts wouldn’t work. The factory ones are ugly without covers though.
Yea those are tuner nuts. Make sure to not lose the silver key (cylinder that fits around the nuts) that should have came with the box.
Ah, I see. I think on these wheels the recesses are wide enough to fit the old lug nuts...but not 100% certain as I did not (in the Dekagram) attempt to fully mount the wheel using a socket.
Other than allowing sufficient clearance, is there any other reason to use them other than street cred? It seems there is more thread engagement but pretty sure that does not actually matter...and it prevents the end of the lug bolt from rusting...and means no need for covers since they color match.
Just would prefer to not have to keep track of a splined tool just to be able to get my wheels off...trying to avoid unnecessary complication whenever I get my wheels.
I assume they were necessary in this case since the tire shop provided them, but just wondering whether it was only for aesthetics...
Give it some time. If you got the right ones they'll work.Having trouble getting the new TPMS to read. New thread here if any of you have any tips:
New aftermarket TPMS won't read...how to fix?
Tesla added a factory reset feature
While parked, go into service -> tpms -> factory reset. At least I think it's in the service menu? It's somewhere
It will force the car to look for new sensors
If that doesnt work, the TPMS discount tire gave you might be wrong
You just need to use a thin wall socket and make sure to press the wheel flat to the hub when putting on the first lug nut or taking the last one off.Regarding lug nuts, at least on Hypergram...stock lug nuts appear to fit fine, but due to tight clearances it's very likely that things will get scratched up by the wider 21mm socket used. I tightened one down and here's the result:
Respectfully I would disagree. Although 200tw tires don't generally heat cycle out the same as a race tire they still last a little longer with a proper heat cycle.Nah, no need for breaking in or heat cycling, they'll heat cycle out anyway long before they cord. heatcycling in advance and letting them sit for 48 hours on a slick normally just gains an extra few heat cycles. R7's can gain like 2-4 additional heat cycles before turning into rocks if you follow hoosiers advices, no such luck for a 200TW tire.
