Todd Burch
14-Year Member
The supercharger is DC...so it bypasses the onboard Model S chargers. (2) applies regardless, and is due to the impacts of high charging rates on battery lifetime.
I'm more worried about battery capacity and longevity for this concern, than efficiency of wall power consumption.Ah...misunderstood when you used the term "supercharging"
I believe buried somewhere in the Roadster threads that the sweet spot for charging and battery life is in the range of 240V 40A, so I'd use a NEMA 14-50 over the HPC in that case. Of course, the chemistry of the 300mi pack is different and the Model S pack might behave a bit different in general.
Regardless, with the lower charging rate you won't waste as much energy cooling the battery while charging.
If the HPC is only for periodic and/or range charging (rather than daily use) that makes it less compelling to me.
Excellent. Do you have any links to detail this? They might help me with the decision. Thanks!The nice thing about the HPC is that you can program the car to draw at 40A most nights, but you'll have the full 80 whenever you need it.
We don't have enough data to know if charge rate affects battery life. Is is likely to be insignificant compared to depth of discharge, temperature, and max charge ( using range mode ).
Tom Saxton's experiments Tesla Roadster Charging Rates and Efficiency - Tom Saxton's Blog found that 40amps to be optimal for energy efficiency.
Ambient temperature, cooling efficiency, charging efficiency of the Model S could easily make it different.
Pretty much. Just tell him you want the standard 14-50 socket. From a sheet Tesla has on their website about the charge adapter "Tesla recommends installing a NEMA 14-50R receptacle connected to a non GFCI 50A breaker".I assume if I called an electrician and told him I wanted a 50amp 240v receptacle that he wold do that without any issue?
I'd wait until the Model S charging sheet is formally released though just in case they have any changes, but in short, it should be a really simple, standard socket to have installed.
I'm curious, why does it matter? Some extra paperwork or fees required?BTW, don't tell your electrician that you're getting an electric car. Tell him you need the 14-50 for an RV you'll sometimes have there.
