Be careful what you buy:Omg
Ffs - I might just sell it now
Me too. I use AP on my commute, luckily on relatively quiet stretches of motorway where to be honest my other cars with cruise control worked just as well. By forcing me to use crap technology that is actually detrimental to safety (no control over high beams is both a safety issue, as well as an offence under the RVL Regs) this will be my first and definitely last Tesla.I’m grateful I don’t use AP often. If this is a taste of the future then my next car won’t be a Tesla.
But strangely, we haven't really seen a mass of complaints from those who took delivery of post-April cars in the UK, either. The odd grumble here or there, maybe, but nothing much.What is amazing is there doesn't seem to be masses of complaints from the US where they've had it a while. You can find threads with these same issues mentioned, but it's clearly not a very loud volume. The fixes are easy, simply don't force on the auto-headlights, if you can turn them off manually and you don't die it's clearly not mandatory.
it’s been summer - light evenings and a record breaking droughtBut strangely, we haven't really seen a mass of complaints from those who took delivery of post-April cars in the UK, either. The odd grumble here or there, maybe, but nothing much.
I know Tesla has a reputation for cost cutting but I really really hope that the deletion of radar was for genuine performance reasons ( avoidance of sensor conflict or something) and not just to save a few quid in which case I would hope so otherwise what was the point in doing it.Looks like 2022.24.6 is appearing in the UK now. It contains the change to flip to vision only for AP (so basic AP, EAP, and FSD). The radar will be turned off. Implications seem to be:
- Auto full beam and auto wipers are forced on when AP is engaged
- Follow distance is now limited to a min of 2
- Max AP speed is reduced by 5mph
Hit on phantom braking is not clear.
Not sure whether this will be a forward or backward step for those of us with radar.
Can't you just turn off the auto feature, by tapping the option that comes up on the screen when you enable AP, instead of turning off the high beams using the stalk? Then you can control the high beams normally with the stalk.Yes, they can then be turned off by manually pushing the left stalk forward, but this has to be repeated every single time. Even doing that, it will then not be possible to manually turn on the full beam lights without continuously pulling the stalk back - and this is not always possible depending on the steering input required.
Even if that worked…every single time you activate AP though. I must activate AP dozen and dozens of times on a typical drive.Can't you just turn off the auto feature, by tapping the option that comes up on the screen when you enable AP, instead of turning off the high beams using the stalk? Then you can control the high beams normally with the stalk.
No you can't. It won't let you turn off the auto button on the lights or wipers while AutoPilot is activated.Can't you just turn off the auto feature, by tapping the option that comes up on the screen when you enable AP, instead of turning off the high beams using the stalk? Then you can control the high beams normally with the stalk.
Vision performance overtook (current low-res) radar quite a while ago. Lots of videos from this time last year showing it operating well in fog etc. Some people don't like change though.I know Tesla has a reputation for cost cutting but I really really hope that the deletion of radar was for genuine performance reasons ( avoidance of sensor conflict or something) and not just to save a few quid in which case I would hope so otherwise what was the point in doing it.
Why is the only Level 3 autonomous vehicle Lidar based then (Merc S/EQS)?Vision performance overtook (current low-res) radar quite a while ago. Lots of videos from this time last year showing it operating well in fog etc. Some people don't like change though.
I don't think anyone was advocating for radar instead of vision. just whether going from two independent sources of data to one is progress. I guess we will see.......Vision performance overtook (current low-res) radar quite a while ago. Lots of videos from this time last year showing it operating well in fog etc. Some people don't like change though.
This isn’t the US where people just sit in the same lane for hour after hour (well middle lane numpties might).
