Really good stuff eprosenx. I have a 20 kw whole house generator with an automatic transfer switch. I’m curious if I could charge my 3 in a pinch paying close attention to other loads. I use a NEMA 14-50 outlet on a 50 amp breaker which charges at 32 amps max. No dryer no oven no dishwasher. There is a 100 amp breaker on the generator itself. Thanks in advance for your thoughts.
Thanks very much.Yes, I suspect you could without any issue. I have used my Tesla to help load bank a friends similar home generator (i.e. put max load on it to prove it works).
I would try it out before you need it just to make sure!
Also, do you have a way to easily monitor load on the generator?
I might consider getting a Sense Energy Monitor so you can track your usage in real time to ensure you don't go over.
I know that you will try anyway, but you will find that it isn’t worth it
A 2000 W generator, if you can get it to work, will be at max capacity and burning a LOT of gas and still take over 24 hours to charge.
That means that nothing else in the house is getting power
Also you will find that most generators don’t have the duty cycle to run that hard for that long. You’ll want to be prepared to change the oil around 12 hours and probably need at least 20 g of gas.
I’ve got a 30kW whole house generator, that I don’t expect to charge the car with.
Moral of story: Big storm = charge to 100% and leave it there.
If you can’t get out to go elsewhere to charge, then you really shouldn’t be getting out
Even if I could, I wouldn't feel comfortable connecting the generator directly to my Tesla. I have a manual transfer switch for my entire house, so I'd fire up the generator and go through the exact same breaker(and Juicebox) that I normally use. Even if the science disagrees with me, I would never want to hook directly into a generator. As other things in the house are turning off and on, I wouldn't want the variation in electricity to hit the car.
I think you are underestimating the fuel consumption of EV charging on a generator. Sure, you can run for 8 hours on 5 gallons of fuel, but it's going to have to work a lot harder and therefore burn more gas if you're charging a car. Don't expect more than 20-25 miles of range per gallon on a generator.I happen to have a Generac GP8000E gasoline generator (8000 watts running; 10k starting) in the garage that we bought after Hurricane Sandy, with an L14-30R twistlock receptacle on it.
My thinking is that, in the event of a major, extended catastrophe (ala Sandy, where I had no power for 9 days and most of the surrounding area had no power either), I'd like to be able to charge from it. That should let me add about 22 miles of range per hour to Model 3. 5 gal of fuel typically runs that generator about 8 hours, so I should be able to put 176 miles of range on it with one tank of fuel.
I need to pick up a NEMA 14-30 adapter for my mobile connector and an L14-30 to NEMA 14-30 adapter to test it out, but as a Plan C, I think this'd work in a pinch. Anyone see a reason why it wouldn't?
If it's not an inverter generator, load variations can cause the generator speed to change and therefore the line frequency. Tesla vehicles used to be very picky about frequency stability, so a Classic Model S, for example, would soon stop charging on a generator. I don't know how picky a Model 3 is these days.Do you think you'll get that many miles per hour? From what I've read you'll be lucky to get 10. That being said, as a last resort I suppose it will be ok. I'm still wary of hooking the precious car up to a power source that is inconsistent.
If you don't want to try to do double adapters like that, the company EVSEAdapters makes really good 3rd party adapters for the Tesla UMC. They plug right into the electronics box of it and keep the temperature sensor in the plug. Here is the one for an L14-30.with an L14-30R twistlock receptacle on it.
