I routinely use the parking brake by pressing the right control stalk button, even on the flat. Is this actually necessary or is it just meant for parking on slopes? I don't wish to stress any components long term if it can be avoided
Ah, OK thanks. Seems some confusion around this searching in Google. I'll watch for the red brake sign when I open the doorsThat’s fine. It applies the brakes when you open the door anyway
You have to be surprised that the car lets out at all if you haven’t complied with all the on-screen directivesThe problem with not pressing the Park button is that you get more irritating bin bong warnings when you unfasten your seatbelt ... and the car then applies Park for you anyway as you open the door of course.
Can someone eplain what's actually going on in hardware here? Conventional parking brake was just a cable to the rear calipers/drum brakes.. Is the e-brake somehow different as in locking up the motor with reverse emf? if so how does it hold when parked? I don't see how otherwie this would help in a situation where say the master brake cylinder failed unless there's a secondary system actuating brake pads by solenoid.
Not an M3 presumably what you have, but on my MX I changed the behaviour from “creep at standstill”, much akin to a traditional auto setup, which required P brake to be applied when stopped - to the “non creep” mode which uses the hill hold function - the service brakes basically. I haven't gone back to creep.I routinely use the parking brake by pressing the right control stalk button, even on the flat. Is this actually necessary or is it just meant for parking on slopes? I don't wish to stress any components long term if it can be avoided
A “friend” did this by mistake, and all it does is bring up a warning on the screen. And the windscreen was still dirtyAnyone accidentally pressed the park button ... ... I do wonder what would happen if this schoolboy error occurred at 75mph on the motorway
