so I’m going on vacation for a week. Should I leave the car plugged in the whole time in my garage or charge to 80% and let it be.
Will be sitting in my garage the whole time.
We have two M3 and only one charger. I have been searching for how to put the second car into some kind of "vacation" mode but can't seem to find the info. does anyone know? Also, it appears Tesla support.com ie chat and email have disappeared. I wish the owners manuel had the ability to search.
I would just plug the second car in with the included UMC on a 120v circuit. Maybe even turn down the charge amps a little if I was concerned with other loads on that circuit. That would be sufficient to offset battery drain just sitting there if it needed to (but unlikely in a week that it would ever need to charge).
Make sure to turn off sentry mode and cabin overheat protection (for max power savings) if it might be hot where you are parked.
The answer to your vacation question lies in these two rules:
- Keep a Tesla plugged in whenever possible.
- The battery is happiest at 50% state of charge.
This is the reason the charge level slider goes down to 50%— for long term storage.Oh? I have heard/read lots of battery advice over the years, but don't recall previously hearing the a "battery is happiest at 50%". Do you have a source for that?
There are so many different opinions on this sort of thing, but little if any specific advice from Tesla, except for the guidance to use 90% or more only for trips....
Add that to the list of stupid things Tesla people have said. We used to have a thread for that but I can't find it.I just spoke to a mobile service technician who said to plug in, leave the battery at 50 % and lower the volts to its lowest number. Lowering the volts will allow the charge to trickle in.
Number one, you can't "lower the volts". It is what it is, depending on the outlet you plug into. You can lower the amps but not the volts.
Number two, there's no reason to lower the amps in this situation. Charging at lower amps just means the charging circuitry runs that much longer, and it uses electricity less efficiently. The car is designed to let the charge level drop by 3%, then charge back up to the set point (50%), then it charges again when the level drops by 3% again, etc. Just leave the car plugged in and let the battery management system manage the battery.
The person should have said "lower the amperage", not volts, but their point is correct. The faster your charge lithium batteries, the more dendrite growth you get that could puncture the separator membrane between anode and cathode, which is eventually what kills a cell. Lowering the charge rate is healthier for the battery. I would rather spend $.10 more on electricity than spend $8k on a new battery module 10 years down the road.
To think you’re going to damage the battery because of charging at 8 kW rather than 4 kW is ridiculous. It’s designed to charge at over 100 kW at superchargers.The person should have said "lower the amperage", not volts, but their point is correct. The faster your charge lithium batteries, the more dendrite growth you get that could puncture the separator membrane between anode and cathode, which is eventually what kills a cell. Lowering the charge rate is healthier for the battery. I would rather spend $.10 more on electricity than spend $8k on a new battery module 10 years down the road.
