Personally, I don't think people are noticing it. This image was from yesterday evening. My power has been out since Monday morning due to the big storm that blew thru here. After 3 ½ days my SOC was low enough, I decided to run some errands and stop by the local Supercharger to charge it up. I kept trips to a minimum during the outage.
As the storm came up the coast, due to El Nino, we got warm rain and winds. That raised the ambient the first two days, and if you look carefully at mile 30, which was Tuesday, the SOC was up. Then Wednesday and Thursday, the temps became frigid, and you can see, the SOC dramatically drops.
The way I look at it, the car's BMS when you start to drive, measures the pack's voltage based upon the ambient when you start to drive. It's not making any adjustment based upon ambient's until you stop, and start to drive again, wherever there's a vertical line. Because of that, you get adjustments, visible adjustments, between the time you stopped and the time you start.
To me, it follows a pattern of, is the ambient colder now than when you last started the car? Yes, then the adjustment is down. Or, is the ambient warmer now than when you last started the car? Yes, then the adjustment is up. It's that simple.
Just to be clear, you can see on the display, it shows it's 27F outside. A couple days before, when I drove from Mile 30 to about 45, it was almost 50F outside, much much warmer than even the previous day in the high 30/ low 40s.
