Peter Lucas
A car with a Rated Range of 280 miles should get you much more than 180 miles. Rated Range is not ideal range. Rated Range was described to me as a realistic range with conservative driving. I figured that 240 to 250 miles was reasonable to expect.So -- let's be reasonable -- you leave at 95% rather than 100% because it is tedious to time things exactly so that you leave the house at 100% and it takes an extra hour to go from 95% to 100% anyhow.
A 90D should have no problem whatsoever doing this.
And you don't want to drive around below 15% because it is reasonable to have a buffer in case there's a traffic jam or the charging station you go to isn't open (though in that case if you're going to a supercharger and it is closed you're actually now in serious trouble if you've gotten that close to the bottom). So that means your effective range with an S90D with "reasonable" degradation is now 220ish miles.
If you can't do 180 actual miles in an S90D there's a serious problem. Further, if your rangeometer tells you you're able to hit a target 180 miles away and you can't there's an even more serious problem.
It would be totally reasonable for someone else to want to go further; for me, in my neck of the woods, going 180-220 miles at a time means you can hop over every-other supercharger and land with 10-20% SOC and charge pretty quickly and have not needed to supercharge more than 2 times in a day.
The variations in range and terrain are such that I wouldn't really expect an S90 to be able to actually drive reliably 277 miles from outlet to outlet; to do that I'd want a car with a "rated" 340 mile range, or more. Maybe that's my range anxiety, or maybe I'm just cynical enough to discount the correctness of "advertised range".
I was justifiably very disappointed to find that 200 miles would require every watthour of the battery.
I was justifiably disappointed to learn that my 6 month old car with a "90" kwh battery only had 72-73 kwh of available energy.
I was justifiably disappointed that the degraded battery still showed a displayed range of an impossible 280 miles.
