What is the definition of long period of time, 5 hrs? 1 day? 3 days?
Exactly what I do!I'd say an hour. If you feel you need 100% battery for a journey, try to time it so that you're leaving as close to when it's done as possible.
The way I've accomplished that in the past at home and hotels is to set it to 90% when I go to bed, and first thing when I wake up I smack it over to 100% to resume charging while I get ready and load the vehicle.
I do the same. Doesn't that last 10% in the morning also warm up the battery?The way I've accomplished that in the past at home and hotels is to set it to 90% when I go to bed, and first thing when I wake up I smack it over to 100% to resume charging while I get ready and load the vehicle.
It became a curse when I started learning about Li-Ion batteries... everything in my house that needs storage I started shooting for 50-80% SoC on. Milwaukee tool batteries, Ego lawn equipment batteries... it's a nightmare keeping track of all of this!this goes with all Rechargeable Batteries-even the cell phones, lap tops etc.
Not great advice…only the LFP needs to be charged to 100% for it to determine its charge state and to avoid calendar aging you want to be closer to 55%. Charging daily to 80%, if you don’t need that range, is putting unnecessary wear and tear on your battery.I charge almost always at home, generally to 80% unless I have a longer trip that day.
I've heard you should occasionally charge to 100% in order to let the battery management system (BMS) balance the cell voltages (or groups of cells). Any comments if this is a good idea, and if so, how often? I don't see this mentioned in the manual, but have read about it at other places.
Now 80% is bad too? Since whenNot great advice…only the LFP needs to be charged to 100% for it to determine its charge state and to avoid calendar aging you want to be closer to 55%. Charging daily to 80%, if you don’t need that range, is putting unnecessary wear and tear on your battery.
If your Model Y has the LFP battery (probably not), charging to 100% is fine and in fact recommended.
I use 30% a day so I go from 80% to 50% by the end of the day, I like having the extra for emergencies even if I don’t normally need itIf you need the range that 80% provides, then charge it to 80%…but if you don’t (I don’t so I keep it under 60%) then the lower the better…the only niggle is that at 20% Tesla takes away some (remote) functionality. I should Tweet at Elon and ask him why his nanny-state engineers won’t let me do what I want with my 20%! If not for that loss of function at 20%, I’d live from 55% - 5%…and charge a little less frequently.
