999 ?
Poster is from Essex in England. That's the standard British emergency number.
The European standard 112 also works in the UK.
Also, if the caller is using a cellphone in the UK 911 may also work.
Interesting thread. My 2018 Model 3 and my husband’s 2017 MS do not have this heat pump so never experienced this and at leadt now won’t be alarmed if at SC and see this happening on newer models.
BTW if you navigate to the Supercharger where the car prepares for it ahead of time, will this preheating prevent the temperature/water vapor “steaming” effect when you start charging?
Same thing just happened, maybe from some windshield washer fluid as I used the wipers shortly before starting superchargerThis just happened to me in my 2021 M3P at a supercharger on the way home from a weekend away. Just sat watching Netflix with my girlfriend, started charging at about 20%, it was about 15 degrees and fairly high humidity, but suddenly a big puff of white ‘smoke’ came from under the front wheel arch! I instantly panicked, leaped from the car and told her to get out, but it quickly vanished, left no smell and after crawling under the car with my phone light I saw no evidence of any issue. The car was giving off some heat, might be heat pump related? The car continued to charge to 80% with no issue, and drove home around 200 miles with nothing to note. Very odd!
I had same issue today. White smoke, no smell, came out around front wheel and under bumper, during superchargering around 50%of battery. The charge speed is 400m/h. Only my car has the smoke come out, all rest car nearby no smoke. My car is 2021 Model Y.
