Why I returned my 2019 Tesla Model X?
Discussion in 'Model X' started by Kashif, Jul 9, 2019.
  1. Yinn
    Yinn Active Member
    Behind you
    Bingo.
    But that’ll slow it, won’t 100% prevent it. Hard acceleration or acceleration under heavy load amplifies the problem. The issue is the design of the suspension geometry.
    Disclaimer: I don’t know if the Raven (with the new dynamic shocks) is a suspension revamp or just a swap. So I don’t know if this is true for the newest models.
  2. phatteus
    phatteus Member
    NYC, USA
    I have a Raven and noticed this also. For me it’s most noticeable at 73-74 mph. No headaches for me so I won’t return, but it is annoying and I hope I get a warranty fix in the future. Cool analysis!
  3. Kashif
    Kashif Member
    Thanks for the confirmation! Good luck for a possible fix in a future. I believe there is a lot of mitigation techniques such as using some dampening material or noise cancellation circuitry etc that can be employed as a engineering solution, but in my case Tesla did not take any action to address it.
  4. Yinn
    Yinn Active Member
    Behind you
    Thank you for the confirmation.
    So even though you don’t own one anymore, hopefully you don’t mind if we lean on your expertise. What do you think the issue is? Do you think it’s related to the Model 3 motor or something else?
  5. Saghost
    Saghost Well-Known Member
    Delaware
    I'm not an audio expert in any way, and as I grow older the fact that I don't hear it in my Ludicrous Raven may not mean anything.
    So I tried the two free frequency analyzers I have on my phone. This is 70 mph in AP on a somewhat rough/loud asphalt freeway in Tennessee with HVAC on and stereo off, and neither shows anything that looks to me like a spike around 4k.
    FD60B624-CA9E-4DB6-AB8D-1B2CA4449027.png FD54E651-9BC5-4009-9216-B053C2189B92.png
    I was also really surprised that you're experiencing a constant frequency for such a wide speed range - you'd think anything drivetrain related would be proportional to the car's speed.
    I'm doing a fair amount of mostly freeway driving over the next couple days, so if there are conditions or settings that make it worse or free apps that might show it better, I'm willing to try to experiment with my car to see if I can duplicate your experience.
  6. KSilver2000
    KSilver2000 Member
    SF Bay Area
    What device are you using to record the sound and what sensitivity do you have it set to?
  7. Kashif
    Kashif Member
    Thats interesting, do you have a dual motor system in your X? From Tesla feedback, it is related to high current drive in the front motor, but I can't speak on behalf of Tesla engineering, but that constant 4kHz doesn't really make sense to me. I have to physically start debugging to root cause it, but too bad I have returned the car. lol
  8. Yinn
    Yinn Active Member
    Behind you
    They’re all dual motors in the X. What models did you guys have? Short range? Long range? Performance?
  9. Kashif
    Kashif Member
    long range
  10. Kashif
    Kashif Member
    You can use any recording device. In my case I used iPhone voice memo with default settings.
  11. Saghost
    Delaware
    IPhone Xs Max at device and app default settings as far as I know.
  12. Saghost
    Delaware
    As I said above, I have a Ludicrous Raven. That means it has the Performance dual motor system - switched reluctance front motor and the latest revision of the original big motor in the rear, rather than the smaller one that SR and LR cars have.
  13. Kashif
    Kashif Member
    #33 Kashif, Jul 9, 2019
    Thanks, one thing I noticed is that in your first graph, noise seem really high that it can bury any 4kHz tone. The 4kHz tone, in my case, is around -80dB. May be you can try turning off HVAC and use a quiet road? If you send me your recording, I can also check it on my end using adobe audition.
  14. phatteus
    phatteus Member
    NYC, USA
    I can add that I had a p90DL for 3 years and had no whine and this is a Raven Ludicrous also in Red. Maybe it’s just the red cars :)
  15. Tes1aOwner
    Tes1aOwner Member
    Canada
    Don't bet on it. Tesla won't fix anything they don't absolutely have to. They are in financial meltdown mode and have turned off every spigot they have. Service is a big one when the cars were designed faulty. I think it is going to take a class action suit to get them to repair things like the shudder.
    • Disagree x 2
  16. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    geez, your new posting history is quite negative...
  17. Tes1aOwner
    Tes1aOwner Member
    Canada
    I don't get your point. Are you implying I am not telling the truth?
    • Disagree x 1
  18. verygreen
    verygreen Curious member
    TN
    what was/is your average wh/mi on old and new car? My Nov 2017 build X 100D uses less energy than March 2017 X 100D I had. Then whenever you have 5 or 6 seats is a visible factor (due to weight change) and then P adds another extra weight consideration (and then the tire size too I guess).
    E.g. if we look at ABRP's recommended value for X 100D at 386Wh/mi at 65 MPH, that's waaay higher than I actually observe.
  19. KSilver2000
    KSilver2000 Member
    SF Bay Area
    /s ?
  20. KSilver2000
    KSilver2000 Member
    SF Bay Area
    In case you haven’t been following the subject of shudder, Tesla is fixing the issue by replacing the half shafts and it seems to do the trick based on people’s experiences that just got it done.
