Yes, I'm talking about the useless energy graph window. I don't find it very helpful myself, but its immensely more useful than the battery state of charge being indicated in a magical 'EPA Miles'. For those that think the battery holds miles of range, the battery meter being indicated in EPA miles is absurdly misleading. In bad weather, with elevation rise, and long stops with the heat blasting, its totally possible to get 1/4 of the indicated distance. For some people these conditions are very real. If the car says '50 miles' on the battery meter, your real world travel distance wont be anywhere near that and you might be mislead into thinking you can make it. At least the energy graph will show you an estimate based on how you were driving recently. So in those bad conditions, you'd have a bit more of an idea. Of course mapping it is a way better estimate, but for that you need to know a destination. It would be easy for someone to think the car 'told them' they could make it, when the battery meter is displayed in miles. It does not adapt for the conditions and is purely an estimate of the energy remaining, which may have little bearing on how far you can go. If you live in a mild climate its probably close enough, but in conditions I see daily for several weeks every year its off by 100-200 miles when full. And occasionally conditions may reach nearly impossible, so some people pull off the road and wait it out. In sub zero weather this inst the best for range. You really have to have the heat hammered and defrosters on to have any degree of visibility. Typical highway speeds vary quite a bit by region, and this has huge impact on range as well. The problem is just too complicated to have an 'average' consumption, its massively varied.
