Midnightsun
I had a 76 Oldsmobile, Tornado. Flip down the licence plate to reveal the filler cap.What about the Zodiac (or was it the Zephyr?) that had the filler cap behind the rear number plate?
Many German cars have their fuel ports on the right side. I read somewhere that the reason is because there are roadside filling stations in Germany that allow you to essentially pull over to fill your car.Well I don't know for certain, but let's say I doubt this
People who lack the cognitive resources to understand how backing in is safer probably won’t be persuaded by this — but just more data points. weird how some people are blinded by their cognitive bias to not see the quite obvious wisdom in backing in most situations.You really believe this? Sorry, at this point it seems like you're making up excuses. Not unlike the people trying to justify the yoke.
Not weird at all. It's quite normal to not be aware there're things beyond what is known.weird how some people are blinded by their cognitive bias
Yup! Bordering on obsessive forum behavior.This whole matter of front in or back in seems to be gaining an importance way beyond what's appropriate
No, but that can be easily avoided by using all the available resources, like mirrors and cameras. We've come a long way since the 1960's!...
Has anyone ever counted the number of cars that get clipped by people reversing into a slot without adequate visibility through the rear window?
It's simply a straw man argument made up by people who don't have real one.Yup! Bordering on obsessive forum behavior.
it's not like there are thousands of people run over in supermarket parking lots on a daily basis
The section you quoted says 2018, rather than 2015, but that coincidental with what makes my point. It was only in 2018 that backup cameras became a requirement!not thousands daily -- but 12k in 2015 for example
So this is one of those things where it is going to take many years for the real life statistics to shift and then the studies on the new data to start showing the new different results.
Having to get a line of sight from the middle of the car's cabin can have its angle blocked and be blind, where a backup camera on the back bumper is immune to that. It'll take time for the population of cars with backup cameras to propagate.
No it isn't. It's straight up geometry. There's an object in the way when you have to look from the middle of the car.I have never been blinded pulling forward from between two parked cars, or pulling forward from between cars on either side of a stop light which is the same thing. The angle is just fine.
It's definitely not. You don't get to deny people's actual experiences. I have had this frustrating thing happen many times, and it never happens (can't happen) when backing out.That is simply a made up case
No, most lifted pickup trucks and most SUVs cause it.1) rarely happens, 2) even I did park between two semi trailers,
Preferable to NOT be able to see before pulling out rather than being able to see before pulling out? Nah, I'll take the other.it is much preferable to pull forward being able to look directly rather than rely on a camera.
I didn't ignore it at all. I specifically agreed that all of the studies that have been done up until now are based on old data from the population of older cars that mostly DO NOT have backup cameras. It's like if studies were done about telephones back when most were landlines or on cameras when most were film. That data was what it was, and the studies will show what they did and how they were used. But as time shifts and phones generally means cell phones and cameras means digital ones, the data shifted and changed what studies show. We just haven't gotten to that point yet where the large data sets show the difference from enough cars with backup cameras yet.All the other experts and data and research that you ignored from the other cites prove it as well.
Backup cameras have a ~120 degree field of view, on a small screen. — try actually doing the real geometry and real effect of being able to process visual cues directly and from a small low resolution screen. Even if I got a magic 180 degree view from a backup camera, I’d rather look for myself directly un filtered
No, no, NO! Quit infusing logic into the argument!but you're saying I should use the backup camera to back INTO the parking slot instead of OUT OF it
And there's a lot less room for error IN the slot then there is OUT OF it
