JeffK
When you said "by definition", I assumed you didn't mean some subset of cases. My mistake.
But let's see your math.
Simple example everyone can understand, let's use your original premise (what I mean when I said "by definition")
if no speed increase is involved in coasting,
Two vehicles go down a hill and maintain constant velocity of 75mph, one is using regen to maintain 75mph the other is coasting to maintain 75mph. Both get to the bottom of the hill and are on flat road still doing 75mph (same kinetic energy at this point).
Which one was more efficient? Which one has stored potential energy from the downhill travel?
Regen obviously.
No math needed as it's common sense *based on your premise* alone.
Now, in the real world it would be very difficult for the same type of car on the same hill with the same conditions to satisfy coasting and using regen to maintain 75mph. Realistically this would have to be two different hills. and if you used regen where you'd be coasting then you'd lose speed and if your coasted where you'd regen you'd increase speed.
