I've posted my frustrations with the Wifi in the past and my car even had it's "connectivity board" replaced to "fix" the problem. After the fix, it connected so I pretty much forgot about Wifi issues and moved on. Since I know new updates are coming, I thought I'd check in on my Wifi. When I pull into my garage (which has a strong signal with 2 of our home Wifi's), nothing. It stays on LTE. When I click on Wifi, sometimes is actually "off" which is odd, since I've had it set to be on. If I turn it on, it says "connecting" and just cycles for a couple of minutes then nothing... showing LTE only. WTH? Has anyone else experienced this? Any solution?
