...The system was also rigged to charge at a level roughly equivalent to plugging into a 110V outlet, so if you were to take this concept unit as-is and try to charge your Tesla’s massive battery completely, it’d take about 50 hours. That being said, the Fulton representative said there’s no significant barrier to a 240V-type charging system, more in line with what an EV actually needs. If and when an eCoupled vehicle system comes to market, it’s likely to be the 240V-equivalent type.
The other interesting part of the device on display was that it was a “piggyback” type – that is, there were no modifications to the Tesla’s charging or management systems. A receiver bolted under the car fed power to an inverter in the trunk or some such place, which then fed power through a wire to a plug that went into the standard Tesla charging port. As far as the Tesla was concerned, it was plugged into the wall as per normal. This is probably the aftermarket application of the device – another option is to wire up a car at the factory to natively charge inductively. That would mean you would park the car over the inductive coil and walk away, with greater efficiency to boot (as shown in the graphic above). Both the piggyback demonstrator and the hypothetical OEM installation can be monitored remotely via a smartphone application or a web interface, much like the big manufacturers were rolling out with their EVs....
