This is either meaningless or inscrutable:
Does this mean that there is a 10kW charging current applied for 7 microseconds? If so, that's a insignificant 0.0194 watts-hours of power added to the battery, which can't be right.his calculations showed that a set of resonant coils and discs could transfer about 10 kilowatts with a 97 per cent efficiency within 7 microseconds - fast enough for the highway.
I took it to mean the power transfer starts within 7 microseconds (when you drive over a coil), not that it completes within that time. But I agree that it is badly worded.
I'm not terribly impressed by simulations. In this sort of device second and third order effects can be very important. If you leave anything out of your model the result can be quite unrealistic.
Hi Doug,
Let's suppose for the discussion purposes that second and third order effects are negligible. If Robert's calculation is correct wouldn't it take an impractically large number of coil to coil energy transfers to result in a useful amount of charging?
It's hard to comment without knowing how their scheme is intended to work, but the large number of coils is probably just the beginning.
- A car moves one meter (39") in 30-odd milliseconds at highway speeds. That's not a lot of time for coils to be aligned (maybe that's where the 7 microseconds comes from?)
- If the coils aren't physically large, then lateral alignment will also matter
- Large coils don't like to run at high frequencies
- Coil resonant frequency is sensitive to temperature, both in the car and the pavement, which can be at different temperatures and have different response curves
- Steel is a lossy material and can alter the magnetic circuit. Aluminum produces a scattering field at a different phase. Both metals can detune the coils. Since every car is different there will be a different impact on the roadway coils.
- There would be a heck of a lot of electronics and wiring under the pavement
Hi Doug,
Perhaps I have made a mistake in my math or reasoning, but even without the complications that you mention I figure that at 70 mph a Roadster expends 300 Wh/mile. If Robert's .0194 watt-hour per energy transfer is correct then it would take about 15,500 transfers per mile to equal the discharge rate. So that would require coils being buried at least every four inches.
Larry
Hmm, somethings off with these two timelines:
Nissan is now working on inductive charging, with the first production application of the technology arriving when Nissan’s luxury arm, Infiniti, launches its new EV model in 2014.
SAE’s timeline shows that the SAE wireless charging standard is slated for completion by 2014.
I just can't see how laying sensitive, high-voltage electronics underneath this is going to be a practical model -- sounds like "great in theory, horrid in practice" ideas. Here in New England, they can't keep a normal asphalt interstate highway in decent condition for more than about three years without resurfacing (scrape off about 2cm of asphalt, rough it up, relay new). Salt-laden water everywhere for four months of the year. This does not sound like a happy environment for delicate high-voltage equipment.
