Replace the first bullet with a user stomping the pedal and you get the same net result -- logs in agreement.
- Somehow (mangled bits, huge noise spike, er, DC level on throttle lines, mishandled exception, you name it) the inverter receives a command to pick.it.up -- all the way.
From someone with such an apt username, I'm surprised at your misunderstanding of the concept of logging and interpreting logs. I've spent my fair share of time poring through gigabytes of logs from hundreds of systems trying to figure out what was the cause, and what was the effect (in my case it's usually something like database A is reporting memory issues, while the application hitting it is reporting slower queries). I'll give you the benefit of the doubt and address my following explanation to those without such a background, and not directly to you.Are you being funny or just not getting it? I'm having a hard time figuring it out since this is just text, after all. It seems there's more than logs going in circles here. (conversations too)
Assume for a moment that this was a software or hardware fault and nobody pressed the accelerator. Unlikely, but humour me for a moment.
So, in this hypothetical scenario, of course the logs would agree! Feel free to point out something that could, but I can't think of any type of logging that could actually prove that this was user error short of a dash cam aimed at the pedals. The log is getting its info from the same place the inverter is getting its signal ... the accelerator pedal and accompanying firmware.
- Software dutifully notes the command sent (100% throttle applied.)
- Other software carries out the command.
- Still other software notes that command was carried out. (Yes, we're speeding up.)
Thanks for the details on how logging works. In my defense I spend the vast majority of my time programming at a rather low level, so I know little about higher-level techniques and theory -- that includes logging.From someone with such an apt username, I'm surprised at your misunderstanding of the concept of logging and interpreting logs.
I'm not upset, just trying to point out what looked like a bit of flawed logic, and I did try to clarify what I perceived as the circular portion. However, it turns out that's not what the argument is about, so it's totally moot anyways. Thanks for bearing with me.Since you seem upset over this and clearly feel the logs present a circular argument then please detail where the circular nature exists.
Did you purchase said car knowing it was a piece of Tesla bad PR history?Digging up this old thread.... I'll just leave this here:
My interpretation of the logs: 100% driver error.
I'm glad to have a third party confirm Tesla's narrative, but I do have privacy concerns. When you use the reset functionality on the MCU (as you should do when disposing of a vehicle), does it wipe the logs and camera data? I hope so, and that this vehicle had just never been reset.Honestly was not aware it was the same car until this morning when I pulled the autopilot camera EDR data.
Wow, small world- that is pretty incredible
I imagine Tesla gets these snapshots when they pull log data? I'd be curious to know, maybe you could share it with them.
According to the logs.... they already downloaded the logs.
There aren't that many smashed Teslas out there to choose from.Wow, small world- that is pretty incredible
