nh-srt8
From one fellow grumpy Yorkshire man to another, well I'll go to foot of our stairs. :wink:Oh my, what would Nora say?
Next time look at charging at one of the 7 eVGo CHAdeMO charging stations in Austin-- it would be even faster.
Only 29mph? I don't see the problem for an overnight.It is possible to use a HPWC without Dual Chargers in your Model S, but it will charge at 29MPH instead of 58MPH.
In the supercharger desert of the I-35 corridor, I am opting to add the dual charger at delivery. I anticipate having to use destination charging at/near blues fests in the Quad Cities, Helena,Arkansas, etc. While I won't need the dual charging at home, there is currently only 1 SC in Iowa, 3 in Missouri , 0 in Arkansas , 2 in Louisiana. It's hard to read about 2 SC in the same California town, 5 miles from each other (Truckee?) I don't know if the investment in the 2nd charger is wise or not, but I'm a long way from the nearest service center, so it's a major time investment as well as money to go back and add it later. ¯_(ツ)_/¯
All good points Lucy.
My point was that if one uses destination charging at a hotel that has an HPWC, I doubt 29 mph would cramp anyone's style. If you are back at the hotel for 8 hours a night, you get 232 miles of range added with a single charger.
Now, if you need to charge while on the road, during the day, then dual chargers are definitely a good add.
Do those top the 40 amp mark? I really do not know.I'm just worried that it won't be a HPWC, more like a charger at a camp ground while I keep alert for marauding possums. :wink:
As much as I applaud Tesla and these establishments for installing HPWCs, I do worry that it makes Tesla vehicles even more "elitist". Why not install 100 amp Clipper Creek / Sun Country units that will deliver exactly the same rate of charge to a Tesla with dual chargers, but also allow pretty much every other EV on the continent to plug in as well?
When I look at the ordering web page for MS, I don't see the option to add dual onboard chargers any more. Is it behind something else? I can't imagine that Tesla would discontinue it as an orderable option...
Does anyone know if Tesla will make the 72 Amp charger from the X standard equipment in the S?
How about a service center installed second 72 Amp charger for 144 Amps total and 104 mph charge rate?
GSP
You bring up a good point on a utility's lower cost charging window, when also using a HPWC.I have dual chargers in my S because if I'm low I can't charge overnight in the 4-hour window my utility provides ultra low pricing. I normally charge at 60A, and 80A is my SOC is below 60 rated or so. I've also had a few occasions where I've had to charge during the day for a fast turn around.
Note: NEMA 14-50 does not provide enough power to leverage the second charger.
There is no cost advantage of a dual charger.
You have to add in the cost for the HPWC and the dual charger upgrade. In many cases the extra cost for a 100 Amp install over a simple 4-50. Even driving 120 miles every day you can fit the vast majority of your charging into the 4 hour off-peak window on a single charger. Only a small part would happen at higher rates. So it would take many many years to just break even. There is no cost advantage of a dual charger.
It's ridiculous that there are no superchargers in Iowa. There should be one in Des Moines, and one in the quad cities.
When I read this article it makes me feel that the money I will be spending on buying MS is worth each and every penny... I agree with you...why not install 100 amp Clipper Creek..but my question to you is are other EV car manufacturers contributing in installing these super chargers? Just wondering
