I am replying to MMD, who wrote something ' interesting' (and a lot of 'other stuff').
In a long post his main defense (I quote : "my core point raised") seems to be: What if Tesla is telling lies about the specification of the Semi and it does not work. For me the 'interesting' part is to to get confirmation that already the only real argument against the Tesla semi left is hoping & praying that Tesla is telling lies about its specification. I think MMD is not alone in that, the same hoping & praying might already be going on in the board rooms of other truck makers.
However it also means MMD insinuates Tesla is telling lies in both official public presentations and on their website. Such position makes any discussion useless. Actually such is libelous. Maybe MMD wants to go there in reaching for last straws, but I will not.
So I write the rest mainly for the other readers here.
For starters, I was not comparing Toyota and Nikola Semi's to other Diesel trucks, but to the Tesla Semi,. I will stick to that, as I have no interest in comparing non-Tesla products with Diesel trucks, at least not on this Tesla forum.
- MMD complains that we do not know some key-specs of the Tesla-Semi, like the maximum power. Lets make an educated guess.
Tesla-Semi has 4 model-3 motors, these are 258 HP each. In the truck Tesla probably pushes it a bit further, but it is well over 1.000 HP anyway. Further on in this post I refer to a source that comes to the same conclusion.
- In the electricity price I was making a comparison, not aiming at exact absolute numbers. We were discussing powering a hydrogen car from Solar. This means you will need approx 4x as much energy from the solar system as a result of all inefficiencies in the hydrogen chain, there is no way around that. Thus, assuming Nikola uses the same panels as Tesla (who will produces these themselves in 2019 when they start delivery of the trucks) Nikola (and Toyota) will need 4x as many solar panels and space, at easily 4x as high cost.
So on competitive position on cost to power the trucks : Game, set & match for Tesla.
On the Toyota truck and the 670 HP specification you were referring to.
I assume you have an understanding how FC cars work, and why they have a buffer battery. FC's are most happy delivering a continuous flow of electricity, they are bad in delivering high peak load. So for peak loads, the system has to draw from the battery. Nikola decided on a 320 kWh for that, and Toyota 12 kWh.
As stated in the article the Toyota truck it uses two Mirai Fuel Cells. The new Toyota Mirai FC Stack achieve a maximum output of 114 kW (153 hp). (Source, Wikipedia). There are two of these in the truck, so 2x = 228 kW (306 hp).
This means, for continuous use, the Toyota truck can deliver a maximum of 300 hp, as the Fuel cells are limited to that. Effectively it is an 300 HP truck, with a peak power of 670 HP.
For the truck to reach its specification of 670 hp, it will have to draw Power from the buffer battery.
In that case more than half of the power has to come from the buffer battery. Let's be nice to Toyota and assume it is exactly half
This means, that other 228 kW will have to come from the battery. Assuming 100% of that 12 kW battery is available for use, it can deliver that power for a maximum time of 12/228 = 0,05 hour = 180 seconds (3 minutes). Well, in real life use it will of course be less than that actually. Remember the 80.000 lb trucks crawling uphill Elon mentioned, ? The Toyota truck will be one of those. If it makes it.
Comparison to Tesla-Semi.
Tesla officially stated that it can drive the 80.000 lb truck uphill at 5% ramp at 65 mph. Continuous speed.
That requires a total of 1600 hp
continously (1,2 MW).
And it can do that for almost one hour before the 1 MWh (or 1,2 MWh) battery is depleted.. WOW !
(I did not redo the calculation, so I am not sure if the Semi indeed has 1600 HP. Source for this : scroll down to MegaWatts).
Tesla's Electric Semi is a Mega Truck > ENGINEERING.com
And it gets better. After driving that almost one hour uphill with an 80.000 lb Semi at an 5% angle (if you can find such a mountain ;-) ) you reached the top, and will go downhill. Now you get a
very significant part of that 1 MWh energy back (maybe as much as 60-80% !!) to continue your journey to the final destination.
In Nikola's case, they get about 30% back in their 320 kWh battery.
TheToyota's Hydrogen truck however gets a " full 12 kWh" back on that long downhill drive. Maximum.
To get rid of the rest of the 1 MWh breaking energy it will have turn it into heat in the brakes (and probably replace these brakes once it reaches the village downhill.
TLDR:
- Tesla's semi can deliver a power continuously that is 4x higher than Toyota truck's 3-minute peak power, and almost 6x more than Toyota's continuous power.
- Tesla has unbeatable power costs compared to hydrogen trucks
@ MMD, again, I will not respond to your post now your core argument is that Tesla is telling lies.
Edit:
P.S. And on Tesla and the LA port, see 2 posts above this one.
