Todd Burch
14-Year Member
If you want to nitpick, better be right. Otherwise it's just sad. Please look up the concept of friction again instead of aerodynamic drag. More specifically Amontons' laws.
I am a mechanical engineer, and I am right. Off-topic, but Amonton's Laws are basic high school level physics principles applying to sliding friction such as the friction that allows your car to accelerate due to tire forces on the road. Completely irrelevent when referring to forces needed to push an object through a fluid.
While sitting on the platform, the tires are not sliding relative to it. As a result, no energy is lost, since losing energy in a closed system requires applying a force across a distance (concept of "Work", another high school level basic physics principle) Since no distance is travelled, no work is done, no energy is lost.
Of course there is some friction in the rails that increases with mass, but this can be mitigated (removed significantly using magnetic levitation) and at any rate, the frictional forces in a well-designed rail system would pale in comparison to the aerodynamic forces at 120 mph, since aero forces increase with the square of velocity. For example...
