@AlanSubie4Life I notice in comparing posts #27 and #39 that you've added a row for 2018 Model 3 LR RWD 310, in addition to RWD 325. Can you tell me what happened when the existing fleet of RWDs was updated to 325 miles of range--was it simply a change in the formula to read a higher range, or was there a change in the firmware that actually wrung more miles out of the existing hardware?
Separately, I'm astonished that the 2020 Model 3 P 18" now has a higher range than my 2018 LR RWD. Clearly there have been drive train improvements along the way (which may be revealed to us in April).
I don't have good answers for you.
Well...I actually removed that row (I replaced the picture...). The 310 rated miles LR RWD is a point of confusion for me, and I'm still trying to work it out/reconcile all the available data.
All of the stuff below on the LR RWD may be wrong. It's a bit of a mystery to me.
I was not paying attention to this stuff at that time, but my guess/understanding is that the rated range constant has never changed on the RWD. I suspect they once had a much larger bottom buffer on the RWD vehicle, or they did more "expansion" of the existing 310 rated miles (so those vehicles would have taken forever to show degradation - see elsewhere, and here, for my unproven theory on how that is managed). I have no idea really. It's possible it was paired with an efficiency improvement - but they've never retested the vehicle in 2019 or for 2020 so we have no idea really.
That being said, what I do know: The EPA requires the energy measured in the test to be made available to the consumer, as I understand it (lockout of an unusable buffer is not allowed, though a usable buffer below 0% is allowed). (However, I don't know what is allowed if you do voluntary reduction...) If that energy were all available, it would have been 79.3kWh. So the 310 mile to 325 mile update probably did not change the available energy.
If I work this out, I will publish the data in a spreadsheet. There are a lot of numbers that don't align in the various data files, unlike for the other vehicles. So it makes it confusing.
Yes, on the Model 3 P it is pretty amazing how much it has been improved. Part of that is due to the efficiency improvement of the rear motor drive (you can see that on the SR+ efficiency increases), the rest is from something else.
