STS-134
Why's Bjørn bitching about the high beam behavior? This is the proper behavior.If this is how FSD with Tesla Vision behaves then it is way worse than radar. I don’t want it!
First of all: https://www.dmv.ca.gov/portal/file/california-driver-handbook-2020-pdf/
Page 87: "Use your high-beam headlights whenever possible in open country or dark city streets, as long as it is not illegal."
Then: CVC 24409
Whenever a motor vehicle is being operated during darkness, the driver shall use a distribution of light, or composite beam, directed high enough and of sufficient intensity to reveal persons and vehicles at a safe distance in advance of the vehicle, subject to the following requirements and limitations:
(a) Whenever the driver of a vehicle approaches an oncoming vehicle within 500 feet, he shall use a distribution of light or composite beam so aimed that the glaring rays are not projected into the eyes of the oncoming driver.
The lowermost distribution of light specified in this article shall be deemed to avoid glare at all times regardless of road contour.
(b) Whenever the driver of a vehicle follows another vehicle within 300 feet to the rear, he shall use the lowermost distribution of light specified in this article.
Tesla isn't being "super late" at switching off the high beams. Most human drivers switch them off far too early. According to the driver handbook, your high beams should be ON until you are 500' from an approaching vehicle, and 300' from a vehicle in front of you traveling in the same direction. But I've noticed that most human drivers tend to use "if I can see another vehicle, I should turn off the high beams" as their trigger to switch them off. This is incorrect, and the driver's handbook explicitly tells you to keep them on until those distance thresholds. If there's a car 0.1 miles away approaching from the other direction (528.0 feet), your high beams should still be ON!!
