RedMod3
I've just got 2022.20.7, took longer to install than usual and seemed to be stuck on 60% for a while. I have a wi-fi access point in the garage just 2m from the car.
Post #385 in this very threadIs the world aware that 2022.24 will let you move the blind spot image around the screen
I think the last few updates have been like that. Eventually it sorts itself out.I've just got 2022.20.7, took longer to install than usual and seemed to be stuck on 60% for a while. I have a wi-fi access point in the garage just 2m from the car.
You can also delay opening the door fully, which also seems to work. A few seconds seems sufficient.20.5 brought the alarm sounding 5 times when the drivers door was opened. 20.5.1 didn’t cure it.
just downloading 20.7. Fingers crossed this will. If it doesn’t, opening the rear door first seems to keep it quiet!
@AnthonyLR presume you’ve getting this too
I suspect the problem might be that you have gone 2 years into the pastSadly, I can confirm that 2020.20.7 continues to remind you that the car has an alarm when you open the driver’s door.
It still sounds 5 times but less if you get your backside on the seat a bit sharpish.
I haven’t tested the theory fully yet, but opening the offside rear door first doesn’t seem to set the alarm off.
It is however, not easy to climb into the front seat from there. 2020.24 might fix that
Easy mistake. I was 8 years ahead after first typing …and at my age it pays to go backwardsI suspect the problem might be that you have gone 2 years into the past
Have you logged a fault? They normally confirm if it is a known problem with a specific fix version.Sadly, I can confirm that 2020.20.7 continues to remind you that the car has an alarm when you open the driver’s door.
You might have a long wait for no stupid bugs to existbut I'm not going to installed it with stupid bugs like this still unfixed.
Yes. Ranger coming Wednesday until it gets cancelledHave you logged a fault? They normally confirm if it is a known problem with a specific fix version.
I'm keeping mine on 2022.16.3 for now - 2022.20.6 and now 2022.20.7 have downloaded but I'm not going to installed it with stupid bugs like this still unfixed.
i've installed 20.7 and have had no alarm issues before or after
Update. Tesla forced an update which never appeared.. they said it was too new and I'd have to wait for my turn again.. they couldn't say how long that'd be.I was thinking that .. till this morning, when I was offered .20.7. Now its stuck at 50%. Manual intervention required methinks.
Looks like they’ve fixed this on 20.7. The complete absence of nags was nice while it lasted.Not sure if this is a bug or not but I’ve just managed to do 6 miles completely hands free without any nags with autopilot on 20.6
I don't know if it's the fact that I've been using my ring on the door pillar to open without activating the alarm or that I went round and opened each other door in turn (locking the car in between) but the alarm now no longer sounds when I unlock via the drivers door - on at least six occasions since the morning including a drive out for a pub meal.Yes. Ranger coming Wednesday until it gets cancelled
